9n rear seats
Posted: Sat Nov 13, 2010 6:09 pm
by polo9n
how do i take my rear seats out, just cant seem to do it
thnks
Re: 9n rear seats
Posted: Sat Nov 13, 2010 7:53 pm
by g__humm
Lift the front up then there to metal bits pull them in and that's the bitten out then you can see the bolt seats for the back. That help?
Re: 9n rear seats
Posted: Sun Nov 14, 2010 11:03 am
by polo9n
ive tryed undoing various bolts from the back but non seem to loosen the seats at all ? i wil take a picture and upload it later today..
Re: 9n rear seats
Posted: Sun Nov 14, 2010 2:19 pm
by polo9n
Re: 9n rear seats
Posted: Mon Nov 15, 2010 2:25 pm
by g__humm
You have to push the seat to left or right if I remember correct
Re: 9n rear seats
Posted: Mon Nov 15, 2010 6:42 pm
by polo9n
they are held in by the bar that goes through seats by a peice of metal thats jus left of the centre, its under the black peice of plastic if u can see that ? it comes out of the two fings at the ends but this still holds it in...
Re: 9n rear seats
Posted: Mon Nov 15, 2010 7:19 pm
by g__humm
It is shorter passenger end push the seats that way then u should be able to move off that then back the other way then they should be out
Re: 9n rear seats
Posted: Mon Nov 15, 2010 7:34 pm
by polo9n
thanks will giv it a go !..
Re: 9n rear seats
Posted: Tue Nov 16, 2010 6:41 pm
by blazeguarder
With the seat folded down, where the seat meets the rear quarter panel, there's a metal catch over the bar holding it in. Push that open with a screwdriver and that will free the outer side. Then you need to lift it at an angle and just generally fiddle with it until the seat slides off the bar holding it in at the centre of the car. It's quite fiddly unless you've done it before.
Just reread this and realised that it's a bit vague. Sorry, but I hope it's of some use to you anyway...
Re: 9n rear seats
Posted: Tue Nov 16, 2010 10:45 pm
by polo9n
came out a treat thanks needed to undo torques tho...
