Page 1 of 2
Horn not working?? *RESOLVED*
Posted: Sun Dec 12, 2010 11:45 pm
by S.Kayani
The horn on my polo gti has suddenly stopped working. I checked two fuses under the dash they seem ok. Any ideas what else it could be? Or where under the bonnet the wiring etc is? Maybe it's been disconnected somehow?
edit:
sorted now! changed fuse 47 (headlight washer fuse) - cheers dantheram
Re: Horn not working??
Posted: Mon Dec 13, 2010 7:18 am
by alexperkins
It can be the steering wheel press behind the airbag
Posted: Tue Dec 14, 2010 12:05 am
by S.Kayani
Ahhh that doesn't sound good! Any ideas how to check that? Expensive? When the horn was working before. It only worked with the key in the car - not when the key out the car
Posted: Tue Dec 14, 2010 7:23 am
by alexperkins
No - just need to take the airbag off and possibly the steering wheel to regrease the connections.
It will only work with the key in as it doesnt work with the ignition off
Posted: Tue Dec 14, 2010 1:19 pm
by S.Kayani
Oh I see. Wasn't sure if the horn was faulty before.
Cool I'll get someone to check it out for me (not confident messing with the airbag)
Posted: Mon Dec 20, 2010 1:54 pm
by dantheram
Mine has packed up to!
Posted: Mon Dec 20, 2010 9:13 pm
by S.Kayani
sad times, lol, any one know where the actual horn is under the bonnet?
had a quick look the other day in the dark but couldnt see it
Posted: Mon Dec 20, 2010 11:36 pm
by dantheram
its above the lip of the splitter on the passenger side, right behind the fog light.
Posted: Wed Dec 22, 2010 11:26 am
by S.Kayani
Nice one pal, that's a great help, I'll have an inspection today
Posted: Thu Dec 30, 2010 1:52 am
by dantheram
any joy?
want to find out what the most likely problem is, i've had all the connectors off at the horn end an still joy.
Posted: Fri Dec 31, 2010 4:05 pm
by S.Kayani
Naa, still not working sadly, think iv managed to find where the horn is, but can't see it, need to put the car on a ramp I think.
Iv checked two fuses under the dash - 19 an 22 I think it was an they seem ok. Not done anything else unfortunately due to bad weather an bein an work - need to get it sorted asap tho!
Posted: Fri Dec 31, 2010 4:37 pm
by dantheram
I only got the contacts behind the steering wheel to check but im not taking that apart. Going to see if any electricity is getting to the actual horn first.
Posted: Tue Jan 04, 2011 11:30 pm
by S.Kayani
yeah good idea, leme know how u get on mate!
Posted: Wed Jan 05, 2011 6:49 pm
by vr6south
Can you hear the horn relay clicking? I had the same problem which turned out to be a loose connection at the back of the fuse panel.
Posted: Sun Jan 09, 2011 5:17 pm
by S.Kayani
yeah i can hear it clicking when i press the horn, how did u figure it out to be that??
