Light behind heater controls , broken :-(
Posted: Fri Jan 21, 2011 8:05 pm
by jhothersall
Hello,
Went over a rather large pot hole, and since then the red coloured lights wont come on, I know how to get the heat unit out, but how do I replace the bulb ?
James
Re: Light behind heater controls , broken :-(
Posted: Sat Jan 22, 2011 1:13 am
by red6n2
small fingers or tweezers, i have quite large hands and had to use tweezers took me about 5 mnins to actuallu change it lol
set the dial to the top then gently pull out the middle dial and the bulb is located in the middle
Posted: Sat Jan 22, 2011 2:30 am
by nigelelliott394
Set the dial to 0 and then pull to reveal the bulb. To remove the bulb you'll probably need some tweezers (which don't grip very well) so I'd recommend needle-nose pliers
Posted: Sat Jan 22, 2011 9:28 am
by alexperkins
A small piece of thin hose actually works well as it sort of locks onto the bulb and you can easily pull it out.
Posted: Sat Jan 22, 2011 4:13 pm
by Verity
God that's just reminded me of my E!!
The lights behind the heater bit was really intermitant, was really annoying had such a mind of it's own
Would go ages not on the suddenly start working and vice versa. I guess it was loose wiring or bulb, I just couldn't ever be bothered to fiddle, even tho I knew it really bugged me.
Posted: Mon Apr 11, 2011 1:42 pm
by jhothersall
thanks for the advice .. its all fixed now :-)
