Wheel info
Posted: Fri Jan 28, 2011 6:05 pm
by g__humm
Basicly want to know what I require for 17 I'm talking the 7j etc stuff want to run 215 tyres too any help guys?
Re: Wheel info
Posted: Fri Jan 28, 2011 11:53 pm
by Pipdub
7j...17"...215........ I'd say 5x100 et 25 up front and 15 out back with a reasonable drop (technix with helpers out will do). As for alloys...whatever has those fitments that u like...or bigger et's and space out to the above? 5x112 and adapt to the above?! For 7j anyway. 8's or 8.5's can be done with correct sums!
That what you're asking?
Re: Wheel info
Posted: Fri Jan 28, 2011 11:54 pm
by Pipdub
Ps 215 on a 7 is wide...? Just fitted 195 on a 7.5 for a mild stretch...?
Re: Wheel info
Posted: Sat Jan 29, 2011 9:34 am
by g__humm
Ok maybe I was not clear I want a recomendation for the size I need
Re: Wheel info
Posted: Sat Jan 29, 2011 1:19 pm
by Pipdub
Tyres? Or alloys or both?
Re: Wheel info
Posted: Sat Jan 29, 2011 2:33 pm
by g__humm
Want a width of 215. That all I know lol
Re: Wheel info
Posted: Sat Jan 29, 2011 5:24 pm
by chewy
215 tyres on a 8 or 8.5 width wheel
Re: Wheel info
Posted: Sat Jan 29, 2011 5:27 pm
by g__humm
Cheers and what offset do I need sorry
Re: Wheel info
Posted: Sat Jan 29, 2011 5:30 pm
by chewy
Something around ET30.
I have 7.5 Et33 they are a slight tuck
I had 9 ET27 with about 25mm poke
Just to give you an idea
Re: Wheel info
Posted: Sat Jan 29, 2011 5:54 pm
by Pipdub
Google 'will they fit', put your original measurements in then try others out and it does the math for you. U can fit a 215 tyre to anything between a 7.5 & a 9. For every half inch wider the alloy add 6 onto the offset you need. It all depends what look you're after...
Re: Wheel info
Posted: Mon Jan 31, 2011 3:10 pm
by west123
I put 18’ on my polo 215/35 I didn’t need to change a thing…ive got no problems with rubbing and I think they sit just right… :D
