Airbox Help!
Posted: Mon Apr 18, 2011 8:04 pm
by chewy_
I need a new airbox for my 2004 1.9tdi (pd100)
The part number on the current airbox is 6Q0129607AR. does anyone know if the below airbox would fit? part number 6Q0129607AG
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Re: Airbox Help!
Posted: Mon Apr 18, 2011 8:12 pm
by K.I.T.T.
Take it you're David's brother (ask me how I guessed :D) 6Q0129607AR is the part no. for the air filter, not the box...
Having said that, if it's definitely off the PD100 (or 1.4 TDI) it will fit. The other part no. doesn't show up on ETKA. Measure the diameter of the hole for the MAF on yours and ask the seller to be a 100% sure.
Ash :)
Re: Airbox Help!
Posted: Mon Apr 18, 2011 8:20 pm
by chewy_
haha yeah I'm David's brother.... not sure how you guessed :lol:
sorry the part number should be 6Q0129601AR I've emailed the seller and asked if they could measure the inlet and to confirm the part number.
Thanks for the help
Re: Airbox Help!
Posted: Mon Apr 18, 2011 10:06 pm
by K.I.T.T.
The problem is the part number you've given (ending in AR) is for the air filter, not the housing itself. The same filter works in either all 1.4 / 1.9 TDIs, but the maf on the PD130 is bigger.
Just compare the maf mounting hole size and you should be fine. Having said that, the air box should be fine as he says it's off a 5 speed Polo ATD. You don't see many GTs about, let alone ones being broken.
Ash :)
Re: Airbox Help!
Posted: Mon Apr 18, 2011 10:39 pm
by chewy_
I've just got home and checked. when I called my local dealers they gave me the part number 6Q0129607AR :?:
I'm confused :lol:
I'll wait to see what he says when he gets back to me.
Re: Airbox Help!
Posted: Mon Apr 18, 2011 10:46 pm
by K.I.T.T.
EDIT: I'm wrong, you're right. They call the freaking air filter box the "air cleaner" and that confused me...how is air cleaner a logical name? :? :lol:
Look at all the "number 7s". The ones that list ATD/AXR will work. Stay away from BLT/ASZ (that's the VRS box you have).
Ash :)
Re: Airbox Help!
Posted: Mon Apr 18, 2011 10:51 pm
by chewy_
just found the below here http://www.seatcupra.net/forums/archive ... 41543.html
ETKA lists the same part number for the Cupra airbox (engine code BBU) as the 150bhp 20V Ibiza (engine code BJX). Part number 6Q0 129 607 G
Same part number but with different suffix fitted to Skoda Fabia ...
1.4 diesel, code AMF. Part number 6Q0 129 607 AR
1.9 diesel, code ATD. Part number 6Q0 129 607 AR / code ASZ. Part number 6Q0 129 607 AJ
2.0ltr petrol, code AZL. Part number 6Q0 129 607 AM
Volkswagen Polo 2003 onwards.
1.4 diesel. Code AMF and BAY. Part number 6Q0 129 607 AR
1.9 diesel. Code ASY. Part number 6Q0 129 607 AE
Re: Airbox Help!
Posted: Mon Apr 18, 2011 10:53 pm
by K.I.T.T.
Check my edited post above, I confused what they meant by "air cleaner" :)
The part number(s) you need are in the diagram above.
Ash :)
Re: Airbox Help!
Posted: Mon Apr 18, 2011 10:57 pm
by chewy_
haha thanks for that Ash :D
Re: Airbox Help!
Posted: Thu May 05, 2011 10:10 am
by chewy_
the search continues. bought the above one off ebay but it never arrived and received a refund... I'd rather have had the airbox :x
Do you know if this one would fit?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _880wt_905
***Edit*** doesn't matter the seller just got back to me and confirmed it has a 80mm inlet so its no good.
Re: Airbox Help!
Posted: Thu May 05, 2011 12:40 pm
by chewy_
Got this from a seller on ebay. This might help in my search
Part Number –
6Q0129607AR
6Q0 129 607 AR
Application -
VW:
POLO 2002-05 MODEL YEARS (9N) WITH AMF , BAY, ATD, AXR ENGINE CODES
POLO 2005-08 MODEL YEARS (9N3) WITH BNV, BNM, BWB, BMS, ATD, AXR, BMT WITH ENGINE CODES
POLO 2009 MODEL YEAR ONWARDS (6R) WITH ENGINES CODES BNV, BNM , BWB, BMS, ATD, AXR, BMT
SEAT:
CORDOBA 2003-05 MODEL YEARS (6L) WITH ENGINE CODES AMF, ATD
CORDOBA 2006 MODEL YEAR ONWARDS (6L) WITH ENGINE CODES AMF, BNM, BNV, BMS, ATD, AXR, BMT
IBIZA 2002-2005 MODEL YEARS (6L) WITH ENGINE CODES AMF, ATD,
IBIZA 2006-2009 MODEL YEARS (6L) WITH ENGINE CODES AMF, BNM, BNV, BMS, ATD, AXR, BMT
IBIZA 2009 MODEL YEAR ONWARDS (6J) WITH ENGINE CODES BMS, BLS, BXJ
SKODA:
FABIA 2000-04 MODEL YEARS (6Y) WITH ENGINE CODES ATD, AMF
FABIA 2005-08 MODEL YEARS (6Y) WITH ENGINE CODES AMF, BNV, BMN, ATD, AXR, BMS, BSW, BLS
ROOMSTER 2006 MODEL YEAR ONWARDS (5J) WITH ENGINE CODE BNV, BNM, BMS, BSW, AXR, BLS
