TDi sport throttle body cleaning
Posted: Mon Apr 18, 2011 11:08 pm
by Keeno21
How do you reset the butterfly afterwards?
The throttle seems to stick momentarly when it's fully open, I've got no experience of the pd engines but even so, I'm assuming this isn't normal?!
Re: TDi sport throttle body cleaning
Posted: Mon Apr 18, 2011 11:18 pm
by K.I.T.T.
Diesels don't have throttle bodies ;)
I'd check it over with VAGCOM for fault codes first.
Ash
Posted: Tue Apr 19, 2011 6:52 am
by g__humm
Should stay open and only shut when you turn it off
Posted: Tue Apr 19, 2011 7:31 pm
by Keeno21
K.I.T.T. wrote:Diesels don't have throttle bodies ;)
Every day's a school day! They must have some sort of valve (butterfly or otherwise) to control air flow though?
g__humm wrote:Should stay open and only shut when you turn it off
I ment that it sticks full open momentarily despite my foot being off the loud pedal...
Posted: Tue Apr 19, 2011 7:54 pm
by g__humm
The bit u see is the anti shudder valve a diesel reving is controlled by the fuel rather than the air. I have removed mine so I have no valve.
Posted: Tue Apr 19, 2011 11:30 pm
by Keeno21
How does that affect running? I assume it improves it else you wouldn't have done it, unless of course you're just a little bit mental...
Posted: Wed Apr 20, 2011 6:43 am
by g__humm
Allows smoother air flow.
