Oil Filter Location
Posted: Tue May 03, 2011 11:11 am
by JoshGTI
I'm planning on starting to service my 9n3 myself. I have all the tools to do the job but was just wondering where the oil filter is located?
Ive had the car up on ramps and had a quick look but could see it. Could anyone point me in the right direction?
Re: Oil Filter Location
Posted: Tue May 03, 2011 11:13 am
by chris meardon
on the front of then engine
There is a plastic cover/splitter running under the first part of the engine, 4 bolts and it slides off, then the filter is very visible.
Oil Filter Location
Posted: Tue May 03, 2011 11:15 am
by JoshGTI
chris meardon wrote:on the front of then engine
Ah that's why I missed it then. Thanks for the info and speedy reply!
Posted: Tue May 03, 2011 11:31 am
by POLOZ
In order to remove the filter, you will need a 76mm Cup wrench. Did my service last week and the oil filter was really a b***h to remove :x, no space at all.
Posted: Tue May 03, 2011 11:56 am
by chris meardon
sometimes they are a pain, best thing to do is when you re apply the new filter use oil on the seal so its easier to get off next time.
If you dont have a cup wrench or filter removal tool a rubber glove and strong arm sometimes works.
Posted: Tue May 03, 2011 1:22 pm
by POLOZ
chris meardon wrote:sometimes they are a pain, best thing to do is when you re apply the new filter use oil on the seal so its easier to get off next time.
Yup I always do that with all my new Oil Filters. This was the first time my GTI had an oil filter change under my ownership :)
chris meardon wrote:If you dont have a cup wrench or filter removal tool a rubber glove and strong arm sometimes works.
Dont think it would work with the fan housing in the way, unless you have small hands :P
Posted: Tue May 03, 2011 3:21 pm
by chris meardon
I did 2 with my hands, took me around 10 mins of huffing and puffing but did it eventually.
I had lent all my tools so had to oil change with just a variable spanner.
It was great fun! :(
Posted: Tue May 03, 2011 7:14 pm
by Tim_GTi
TDis have paper elements, much easier but disgusting!
Posted: Tue May 03, 2011 10:56 pm
by gti-joe
I found if you take the 3 screws out that holds the fan onto the housing, so you can move the fan about a bit, makes things a bit easier by giving you more room.
Oil Filter Location
Posted: Tue May 03, 2011 11:07 pm
by JoshGTI
Cheers for all the tips and info guys. Going to give it a go this weekend.
Posted: Tue May 03, 2011 11:17 pm
by loud
lol you think it's bad changing that, I had to change the camshaft sensor a couple of weeks ago which is like above/next to the oil filter and didn't have a spare oil filter so had to change it with the oil filter still attached...what a pain in the ass trying to get the clip and bolt undone in such a tiny space!!!
