VW POLO NREG 1.4cc- Starting problems
Posted: Tue Jun 14, 2011 7:01 pm
by raznutz
Turn the ignition on but the car dont start. Checked the starter motor no problems with it. But the car starts sometimes and then suddenly dont start.
Its a VW Polo N Reg 1.4cc.
Re: VW POLO NREG 1.4cc- Starting problems
Posted: Wed Jun 15, 2011 8:48 am
by sixen
sounds like the ignition switch, quite common
Posted: Wed Jun 15, 2011 8:51 am
by raznutz
hi,is there anyway me checking it is that?
Posted: Wed Jun 15, 2011 12:40 pm
by sixen
not really, but those are the symptoms, try wiggling the key as you start it, and rock the steering wheel. but again the only way of ruling this out is to change it and see if its the same. git of a job mind, part is cheap though
Posted: Wed Jun 15, 2011 5:11 pm
by raznutz
thanks
Posted: Sat Jun 25, 2011 8:41 pm
by sully08
check your ignition distributor, there a common thing to go with out warning on polo's. it's the little black box about 2"x2" thats bolted to the bulkhead on passenger side.
