256mm polo 6n/6n2 front brakes,hubs,calipers etc
Posted: Fri Jul 08, 2011 8:51 am
by sixen
Pair of front swivel hubs, disks, pads (used but near new) calipers carriers intact hoses. removed from a polo 6n2 diesel, will fit 6n or other 6n2 with standard 239mm forged carriers. these are bolt on, 256mm brakes. great upgrade as they are or you could go 280mm with ease :D wheel bearings are good, no noises or grinding when rotated. lower ball joints are good. was going to fit them to my polo, but the Nike Air Hyperballer's just dropped UK so i need them more :lol: grease on one of the hubs is from the split cv on the original car, nothing a wipe wont fix. brake flexy hoses also intact. basically a quick easy upgrade, all you would need is some brake fluid to bleed them up after fitting. surface rust on the disks will rub off as soon as they are used.
£80 the pair, BARGAIN!!!!
near Cardiff
can post, but its not cheap as these are heavy looking at £25 mainland uk
Re: 256mm polo 6n/6n2 front brakes,hubs,calipers etc
Posted: Sun Jan 01, 2012 1:52 pm
by e10imz
hi i know its a long shot but have u still got any of the bits my number is 07806099934
Posted: Tue Jan 03, 2012 1:17 pm
by sixen
hi, sorry all i have left for brake upgrade is 22mm master cylinder and conversion pipes
