annoying rattle pd100 tdi
Posted: Fri Jul 22, 2011 12:36 am
by Dub_Dan
i have a really annoying rattle coming from the dash! only at very low revs it then disapears after 15-1600 rpm anyone else had this or suggest anything
thanks
Re: annoying rattle pd100 tdi
Posted: Mon Jul 25, 2011 11:42 am
by Dub_Dan
ANYONE!?!!?!?!?!?!?!?!?!?
Posted: Mon Jul 25, 2011 11:53 am
by Ladiesman_317
i get this, but only when i start it first thing in the morning especially if its cold, not sure why it happens though. One thing ive found out about these cars is, once you rectify a problem like this, theres always something else which will start making a rattling noise!
Posted: Mon Jul 25, 2011 5:54 pm
by Dub_Dan
ah well at least im not the only one thanks for the input mate...
dan
Posted: Mon Jul 25, 2011 6:10 pm
by Ladiesman_317
I can list another one or two rattles that you may come across, the main one is the passenger seatbelt buckle, which is unbelievably annoying i would happily disconnect it and chuck it out on the dual carriageway! I've somewhat rectified it by attaching some felt tape on it, that said, it does rattle occasionally. Another would be the glovebox or doorcard, cant find out which one it is.
OR, maybe i just bought a $H*T 9n....
Posted: Fri Jul 29, 2011 11:10 pm
by wildman_33
Mine used to under the dash near the windscreen on the driver side although it stopped after i had the dash removed when my aircon was being fixed. I wouldnt bother taking the dash out to look though as you will probably end up with more rattles. I just tend to turn up the music and ignore it.
