Page 1 of 4
SooperDR's - Build Thread!!
Posted: Wed Aug 17, 2011 8:34 pm
by SooperDR
SooperDR is very happy as I am now the proud owner of a 6N2 Polo GTi.
She is a 'W' 2000 6N2 Polo GTi Black 3-Dr, with 75,000 miles.
Everything seemed great, fantastic service history and a very careful owner..
That was until the drive home.. :?
First.. The Passenger side window packed up.. I've checked the fuses and switches.. I'm guessing this is the Motor/ Regulator..??
Second.. Just after start up the car starts to run as smoothly as a diesel.. Vibrating and Shaky and Constantly Hunting on Idle..??
Third.. The Handling.. At a bit of speed, especially on the 'Twistys' the car feels nervous and almost unstable and unpredictable..??
Any or All suggestions very welcome!
Re: SooperDR's - 6N2 Polo GTi
Posted: Wed Aug 17, 2011 10:31 pm
by Bradley
Where abouts in Kent are you located?.
Posted: Wed Aug 17, 2011 10:58 pm
by SooperDR
Just outside of Bromley, on the London side..
Posted: Thu Aug 18, 2011 1:07 am
by bradley1983
Have had a few of them issues.
Idol-I changed my plugs and cleaned my air filter. Mine was perfect after. Also check all HT leads as I hear they are a problem on these.
Handling-I brought some second hand shocks as my rear ones were bad and that fixed the problem.
Window- my wire in the drivers door where it opens and closes (in the black tube) blew. And in my old Gti the switch packed up. So it could be either.
But hey, I'm in Gti no2 and thinking about number 3 soon.
SooperDR's - Oil in Airbox..??
Posted: Thu Aug 18, 2011 2:15 pm
by SooperDR
Cheers Bradley!
I checked the HT Leads and Replaced the Spark Plugs
Then I got the Airbox off and cleaned the Throttle Body, Filter and Airbox.
HOWEVER: I also noticed there was quite a lot of Oil in the R/H Side of the Airbox around the Rubber Seal for the Throttle Body..
Is that tube that runs through the Airbox the Crankcase Breather.. And why would there be Oil in the Airbox..??
Re: SooperDR's - Oil in Airbox - Twitchy Handling..??
Posted: Thu Aug 18, 2011 4:51 pm
by neilGTI
You always get traces of oil in the airbox, nothing to worry about.
As for twitchyness, is it lowered on coilovers ? If not i would recommend them
Posted: Thu Aug 18, 2011 6:51 pm
by SooperDR
At least that's 1 thing not to worry about..!! :)
It's completely standard and on the original suspension as far as I can see..
I have been looking on Venom Motorsport at their AP Coilovers. Any good..?? Or what else would you recommend..??
Are there any other suspensions components worth checking/ upgrading when I do the Coilovers..??
Posted: Thu Aug 18, 2011 7:32 pm
by Trottagti
Handling will be your shocks gone mate, new suspension needed and your anti roll bar bushes will be shot upon inspection...
Oil is ok in the box mate, as for the coilovers I have them and they have been wicked.. No problems at all.
Just a hard ride.
Ht leads sometime break up inside and ark, I changed mine and then there was no probs.
Posted: Thu Aug 18, 2011 7:54 pm
by bradley1983
It's nice to know all Gti owners have the same problems. Lol
Posted: Fri Aug 19, 2011 9:58 am
by neilGTI
I have the Hot Tuning (TA Technix) coilovers on mine, bargain at under £200 and they have been on for nearly 3 years now with no problems, ride is comfy too.
Only thing i wish i had done is re-grease the adjusters when I changed my wheels from 15-16 inch (Highered the car an inch for the 16's to fit) because they have seized now which means now I am back down to 15 inch wheels I cant lower it any more than what it is set at. Makes no difference to handling though, just how it looks really.
Re: SooperDR's - Build Thread!!
Posted: Mon Aug 29, 2011 10:27 am
by SooperDR
Time for a Build Thread:
Thanks to Venom Motorsport I parted with many pounds and now have:
AP Sportfahrwerke - Coilovers.
PowerFlex Front Wishbone Bushes.
So this weekend the Front and Rear Suspension has been removed.
Now for the Wishbones..
Posted: Mon Aug 29, 2011 11:08 am
by Trottagti
Nice one fella.... Ul be happy with them and can chuck it into the corners.....
Posted: Mon Aug 29, 2011 4:11 pm
by SooperDR
Trottagti wrote:Nice one fella.... Ul be happy with them and can chuck it into the corners.....
Wishbones are out! Now to find a friendly Garage to fit the PowerFlex bushes for me..
After a bit of time on eBay and giving them many pounds, I have ordered myself Upper and Lower OMP Strut Braces too..
Posted: Mon Aug 29, 2011 6:26 pm
by Trottagti
Nice mate, fitting mine this week hopefully. Arb bushes also help as they will be shot...
Posted: Tue Aug 30, 2011 3:45 pm
by SooperDR
PowerFlex Wishbone Bushes being fitted tomorrow.. :D
ARB Links and Mounts ordered..
Lower Wishbone Ball Joints ordered.. :)
Combi Drilled and Grooved Front Discs (280mm), EBC Red Stuff Front Pads.. :D
Brembo Rear Discs and Pads..
G60 Caliper Carriers ordered.. 8)
(Do the Carriers bolt in direct fit, or is there much work to get them to fit?)
