Badge Removal
Posted: Mon Oct 03, 2011 5:51 pm
by cr44
Just about to pick up my 6R and wanted to remove the POLO and 1.4 badges from the boot.
I'm sure some of you must have removed them but was hoping someone could give me some tips on how to remove them easily without damaging the boot and second I just wanted to make sure they were stuck on with a sticky back and not metal pins that would leave holes in the boot.
Re: Badge Removal
Posted: Mon Oct 03, 2011 6:53 pm
by tt509
think they are sticky back mate
Re: Badge Removal
Posted: Tue Oct 04, 2011 7:07 am
by john.p.clegg
Yep,just stuck on with goo,I used a length of button thread and "sawed" mine off...
John
Re: Badge Removal
Posted: Tue Oct 04, 2011 11:11 pm
by ChrisRaeburn
As others have said, it's extremely easy to remove the 'POLO' and 1.4 (1.2 in my case!
). Arm yourself with a hairdryer and the strongest thin thread you can find. Blast the section you wish to remove with the hairdryer until you can wiggle it with your finger, pull the thread tight and 'saw' through the sticky back bit. Rinse and repeat until your boot is clean. Afterwards you may need to use some adhesive removal spray/liquid to scrub off the remains (halfrauds does some for pretty cheap which works quite well).
Looks beautiful when it's done and you can have a laugh as well:
Re: Badge Removal
Posted: Wed Oct 12, 2011 6:22 pm
by cr44
All them tips worked well, and that spray is called Sticky Stuff which worked a treat on the residue.
For future reference.... if like me you can't get a hair drier to the back of the car, use quite warm (NOT BOILING) water and that helps quite a lot.
Re: Badge Removal
Posted: Thu Oct 13, 2011 12:33 am
by blazeguarder
I removed some badges from an Audi the other day. Found that dental floss worked quite well to saw through the adhesive, although you need a decent length as it snapped a couple of times! Clay bar sorted out the remaining adhesive on the tailgate and only took about 5 minutes to do.
Re: Badge Removal
Posted: Mon Dec 19, 2011 4:07 am
by Rubz94
All the tips are good! Ive found that using a hair dryer or hot water to loosen it then placing a thin card such as the thin plastic calling car at the corner of each letter and pushing while moving the card left and right takes of the adesive and badges at once and it does not scratch the car if done carefully. Ive done it a ou three times with great results.
