IMPORTANT ALL MEMBERS
All members need to read the following page The new General Data Protection Regulations 2018 (GDPR)
Failure to read and accept the new privacy policy may result in your account being deleted, so please take a quick read
The UK-Polos.NET Admin Team
6R - Multifunction Steering Wheel Retrofit
Post Instructions on DIY modifications here - use all information with caution!
dillan_94
Drives: 1.4 GTI
Re: 6R - Multifunction Steering Wheel Retrofit
Post by dillan_94 » Sat Jun 10, 2017 7:59 pm
Hi Guys,
I own a VW 1.4 Polo GTI DSG which hasn't come with no mfsw controls. It has an RNS510 fitted from a garage.
I've been scouring the interwebs looking for specific controls for my steering wheel but can't seem to find any.
My question is, do I need to find specific controls for my steering wheel or would say Golf R mfsw controls that actually fit my steering wheel work?
Would there HAVE to be coding done or is it possible some functions will work without?
And lastly has anyone from the UK had this done by a dealer or garage? My main issue is not being able to find the parts.
Cheres guys.
Drives: Polo 6R 1.2 TDI
Post by iichel » Mon Aug 07, 2017 4:11 pm
Any Golf 6/Polo 6R MFSW will work.
Coding is done as described in the 1st post of the topic.
Pictures as saved by age69: https://drive.google.com/open?id=0BxYPV ... HBkdmJKMk0
Jay-Jay
Drives: Polo 6R HighLine 1.2 TSI 105cv
Post by Jay-Jay » Tue Aug 22, 2017 11:30 am
I've been able to install the two extra wires pretty easily with few tricks:
- I took the LIN bus from driver's door connector (T28a, pin16), which is more more easy to reach, instead of connector T73b, pin 17.
- I used fast electric connectors instead of soldering.
I've also made an important discovery about the airbag wiring loom.
Its code changes depending on the year of your Polo (to be more precise, depending on the version of connector ring and steering colum switch which is related to the car's production date).
This is how it works:
- 5K0971584A for Polo made till 16-05-2011;
- 5K0971584C for Polo made from 16-05-2011 to 23-07-2012;
- 5K0971584D for Polo made from 23-07-2012 onward.
dsorinn wrote:
Wed Jul 27, 2016 8:07 am
Hey guys,
I just fitted a highline steering wheel with MFSW but I have a problem. [...] my BC buttons don't work.[...]
Could it be the slip ring (my polo is the first generation, 2009-2010) or the airbag wiring ? my airbag wiring has a "D" at the end instead of "A" and the slip ring has an "E" at the end. The steering wheel is made by TRW in 2016, the same with the wiring.
Yes, your problem is the airbag wiring loom! You need the wiring with the "A" at the end or you need to install a newer connector ring with a new steering column switch compatible with the airbag wiring you have.
I have a question:
What happens if my steering column switch already has MFA buttons? Will they enter in conflict with the ones on the steering wheel? Or will they both work in parallel?
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 » Wed Sep 06, 2017 12:50 pm
Found this after searching a lot.
it seems Chinese locale has such flat bottom steering wheel in golf and polo for some time (3 year old youtube video).
  • Without cruise on steering
[youtube]https://youtu.be/ZsTeBGqIVw0[/youtube]
  • With cruise on steering
[youtube]https://youtu.be/SJN4ErkOFlI[/youtube]
This is how you (should) puncture the dimples in back of steering to take off the airbag
[youtube]https://youtu.be/E5LteoUYzKQ[/youtube]
Post by iichel » Wed Sep 06, 2017 7:23 pm
that looks like twice a golf 7, not a polo ;)
ag69
Post by ag69 » Thu Sep 07, 2017 7:08 am
You are right iichel.
Videos are from Golf. I could not find video of Polo.
However here is link to photo.
http://www.vw.com.cn/content/dam/vw-ngw ... ed/img.jpg
It is from cross polo. Again this does not have paddles. But i think with automatic cross polo ,there could be option for paddles.
Chinese local has 1.4 Manual, Automatic and 1.6 Automatic options.
JamesG
Drives: I drive a weird Polo (Skoda Fabia)
Post by JamesG » Sun Sep 24, 2017 6:55 pm
Hello, I am from Briskoda as this post works the same with my fabia but the pictures have since gone! Can anyone give me a link the images? or can they be re uploaded.
Thanks.
Post by iichel » Mon Sep 25, 2017 7:55 pm
Thanks.
lukafoto
Drives: A2 Polo 6R conversion !
Post by lukafoto » Wed Jan 03, 2018 4:49 pm
Any chance to get the photos back for this guide or does anyone have a pdf version available?
martijnoss
Drives: polo 6r
Post by martijnoss » Sat Jun 16, 2018 9:49 pm
Hello
I am planning to change my steering wheel tomorrow.
can someone tell me if these parts are the right one, the steering wheel fit and my airbag also but do i have the right cable and slip ring.
cable
5K0.971.584C
slip ring
6Q0 953 503 EC
Also the +12v cable i can put it to the light switch or the contact switched fuse box, i have an auto light switch(cable form iichell) doe someone know the right pin number?
And are there differences except the place of the cable?
Thanks for youre time.
golffather
Post by golffather » Mon Sep 10, 2018 10:37 pm
Great guide, works perfectly :)
As mentioned, Linbus can be taken from T28a/16 from the door connector, on RHD cars too.
