2008 Polo - question
Posted: Fri Nov 11, 2011 11:57 am
by goldenwonder
My missus has just upgraded her older 2006 55 E Polo to a 2008 Polo 1.2 70 Match - a nice little motor!
I've got a couple of question though - first one is I've noticed quite a dramatic increase in wind noise in the new polo above 50mph, with an irritating whistling noise! I've checked all the door seals and windows etc and all seems ok. It seems to be coming from the windscreen though - and not just one side?
The other question is about the canbus wiring. I've had to removed the RCD200 as its packed in. I put a nice simple Pioneer unit in using the ISO adaptors provided by my local motor factor (marked as for a Golf Mk5?) and it works - but doesn't power off with the ignition. I guess this is down to canbus - can anyone tell me what to wire my 'live' on the stereo to that will allow ignition control? I guess the cigarrette lighter is an option but how do I get to the wiring for that?
Thanks in advance!
Re: 2008 Polo - question
Posted: Fri Nov 11, 2011 12:03 pm
by Dub_Dan
wrong section buddy
Posted: Fri Nov 11, 2011 12:06 pm
by goldenwonder
Argh what a numpty!
Can the mods move this?
Posted: Fri Nov 11, 2011 12:25 pm
by K.I.T.T.
Doesn't really matter, 9n and 9n3 are 90% the same anyway.
The stereo isn't turning off because the switched live and permanent live will be wired oppositely. It's a VW tradition. Swap the yellow (or yellow/red) wire and red (or red/white) wires on the ISO apadter around and it should do the trick. If the loom that came with your Pioneer (HU to ISO connector cable) is like mine, it should actually allow you to do this quite easily as most of them have butt connectors for these two wires to enable swapping these connections around.
This may help:
http://www.installdr.com/harnesses/vw-wiring.pdf
Can't help on the wind noise issue though. I feel my 9n suffers quite badly from wind noise. I always have the stereo on though, so it doesn't matter.
Ash
Posted: Fri Nov 11, 2011 12:45 pm
by goldenwonder
Ta for the info - I've posted this in the right section now!
Posted: Fri Nov 11, 2011 5:37 pm
by Dub_Dan
goldenwonder wrote:Argh what a numpty!
wasnt having a dig buddy just for future reference thats all. sorry if it came across rude
Posted: Sat Nov 12, 2011 10:40 pm
by chewy
Do you know if the windscreen has been replaced?
Have a look at the logo on the windscreen (Should be near the tax disc iirc), if it does not have the little vw symbol then its been replaced badly.
Posted: Tue Nov 15, 2011 1:32 pm
by goldenwonder
I know the cars history pretty well as it used to be my mothers!
Never had a replacement windscreen. This whistling noise is now doing my head in! I've even tried taping around the edge of the windscreen to see if it was there but it made no difference.
I've elimated the following:
- door mirror (makes no difference if you fold it in/cover it)
- windscreen (taped around edges but no difference)
- windscreen wipers (genuine VW ones still on - noise doesn't go when wipers moved)
- door seal - seems to make no difference when you pull the door in, plus it sounds like its outside, rather than wind whistling 'into' the car through a gap, if you see what I mean
Its definitely the sound of wind whistling over something - with the window down you can here it loud and clear so it must be something on the external of the car that is causing it!
Next stage is checking underneath/removing the aerial. Previous 2006 polo didn't have this issue and the only difference on the exterior is the fog lights and alloy wheels.
Posted: Tue Nov 15, 2011 1:36 pm
by goldenwonder
Dub_Dan wrote:goldenwonder wrote:Argh what a numpty!
No offence taken! I hadn't even realised there was a MkVII thread
