Wow, haven't updated this for ages.
Right, will try to get upto speed.
Since last updated, I have:
- Lowered more, removed helpers and cut bumpstops
- Refurbed wheels and got centre caps
- Got it sat on the BBS'
- Upgraded to a 6N2 GTi steering wheel
- Alarm and Remote Central locking installed
- Put standard grille back on
- Upgraded to a GTi Splitter
- Polished rocker cover and got a BMC CDA air filter
- Full service and more genuine parts done to engine, including air flow mass sensor, inlet gaskets, thermostat, etc.
- Handbrake plate welded
- Picked up spare open air roof
- Both door locks fixed and various new central locking pumps.
- picked up genuine roof bars
And now some pictures..
GTi wheel
Anddd picture dump. Btw it might not all make sense due to copy and paste large quantities haha.
Check out my power gain
Took the rocker cover off to remove the gasket....
Had no idea how much of a pain it was going to be to remove
Took me so long to dig all of it out....
Few randoms:
One from the Rolling Road... had to go forwards as it got stuck going on reverse
meant I had no cold air machine either!
Polished Rocker Cover
Fitted all the new gaskets:
and all fitted including new rocker cover bolts
However, broke 2 HT leads and now need a new set. fuuuuuuuuuuuuuuuuuuuu
Not much changed lately. Has been cleaned and polished and it gleams! (yes even through the lacquer peel and rust ).
Anyway, some plans that I want to get done soon......ish:
- Remove the ARB completely, strip it down and clean it up (for the future)
- Replace the passenger window mechanism
- Fix the passenger rear door card
- Tint the fogs yellow
- Pressed plates
- Rear spacers
- New exhaust / custom?
- New bushes and wishbones (doesn't really need doing but looks like they've been on there for a while...)
- Fit a replacement open air roof and sort the rust on the roof.
- Replace all seals on the roof
- Upgrade to 6n2 roof strips (would also replace with a 6n2 windscreen if my chip ever gets worse)
Slightly in the future:
- Respray bonnet, bumper and wings (first)
- Cut rust out and respray car. <- Will most likely be panel by panel mind.
OR. save my money and get a Corrado .Will start cracking on with the small bits for now...
Also,some s**t pictures messing about the other day:
Latest update:
Managed to pick up a spare Open Air roof, motor, wind deflector, seal and headlining today all for £20!
Will buy a replacement cover for the top and re-condition this one as the inside headlining of the roof is in better condition than mine.
Only picture is of donar car:
So hopefully that's another thing on the mend!
Dave
