Page 1 of 2
My gt spec
Posted: Sun Nov 20, 2011 7:24 am
by g__humm
I haven't done one of these for this car even tho I have owned the car for 3 years
Ok start small get to big
Interior
Boost gauge
Nos arming switch
Otherwise standard
Exterior
Full votex kit
Roof painted black
Black wing mirrors
Standard wheels just refurbished black with diamond cut face. on Toyo r1r tyres
C6 ariel ( stubby thing)
Brakes and suspension
Standard fronts with black diamond disc and pads
Rear brakes 256mm vented standard disc and pads
Front braided hoses
Painted in a light blue
Ap coilovers with custom fk rear springs to go lower
Whiteline rear arb
Ebiach front arb
Omp front upper and lower strut braces
Forge rear strut brace
Polybushed all round
Engine and transmission
Pd150 stage 2 hybrid from turbo dynamics
Forge fmic
Jabba sport cone in a box air filter
Jabba sport gas flowed head
Miltec turbo back with Decat and stealth tip
Colt cam
PD 160 intake pipe
Mapped by r tech
To go on very soon
NOS!!!!!
Will get pics up after work hopefully
Re: My gt spec
Posted: Sun Nov 20, 2011 5:25 pm
by Simon90
Fk custom rear springs...
How much lower? N where you get them from?
Could do with a set
Price if possible?
My gt spec
Posted: Sun Nov 20, 2011 5:29 pm
by benmkiv
Nos withe diesels is complicated though??
Re: My gt spec
Posted: Sun Nov 20, 2011 6:22 pm
by g__humm
benmkiv wrote:Nos withe diesels is complicated though??
More simple than on a petrol. In the way you just put it on and go.
Forgot vibra technics engine mounts too
And fk headlights too
Springs were bought from an owner on here never went on his car. Email them
Re: My gt spec
Posted: Sun Nov 20, 2011 9:23 pm
by g__humm
images
How i bought the car
wheels coil overs and brakes done
FMIC
And my favorite last (you must have seen this one by now)
My gt spec
Posted: Sun Nov 20, 2011 9:36 pm
by benmkiv
Nah not as simple since of you just put nos through the intake wih the diesel it ignites far too early and will break something!
Re: My gt spec
Posted: Sun Nov 20, 2011 9:52 pm
by g__humm
The nos is an oxidiser in a diesel which means it just gives the engine more oxygen to burn. Just like using a turbo effectively. Y would it ignite too early? It's air mixing with extra air until it gets into the cylinder then your injectors put in the fuel.
My gt spec
Posted: Sun Nov 20, 2011 10:01 pm
by benmkiv
Take a read through this it's all about the compression rate at which the fuel ignites ::
http://www.nitrous.info/diesel-nitrous.htm
Re: My gt spec
Posted: Sun Nov 20, 2011 10:16 pm
by g__humm
I have done the reshearch and if you read this properly you will see there is nothing to worry about. I am having nos injected into the inlet nothing else no diesel or propane. The extra fuel comes from the original car injectors.
If you call the wizards of nos they ask does your car smoke? It will not break anything. Look in there forum most of the diesels on there run a dry shot of nos which is my setup.
Re: My gt spec
Posted: Sun Nov 20, 2011 10:37 pm
by g__humm
Re: My gt spec
Posted: Sun Nov 20, 2011 11:12 pm
by Dub_Dan
how long does the nos last?
Re: My gt spec
Posted: Mon Nov 21, 2011 7:02 am
by g__humm
Dub_Dan wrote:how long does the nos last?
Depends really spoke to devenutopia on Tdi owners club and on the 75hp setting it
Last 30 min. I will only be using the 25 just to remove the soot that comes out
The back
My gt spec
Posted: Mon Nov 21, 2011 2:57 pm
by benmkiv
The way nitrous works really interests me, did anyone see the 1.8t TT in redline? He'd got a nitrous spray setup for low rev boost before the turbo kicked in and due to it being post manifold it also aided as a spray cooler for the FMIC it was genius!!
Re: My gt spec
Posted: Mon Nov 21, 2011 3:18 pm
by g__humm
benmkiv wrote:The way nitrous works really interests me, did anyone see the 1.8t TT in redline? He'd got a nitrous spray setup for low rev boost before the turbo kicked in and due to it being post manifold it also aided as a spray cooler for the FMIC it was genius!!
No cant say i did see that but nick at R-Tech is running nos as a anti lag on his car next year keep an eye out for it. nos is cheap mod really £450 for the kit £350 to have it fitted but then you can get it to give lots of power more derv owners should run a dry set up for some power you could max out the injectors on a pd 100 and use a 50hp shot of nos (dry) then they would run about 180hp and no black smoke alright they loss 20hp worth of nos out the back but it would be good laugh when people say what you done to that? put nos on it
(Dan im talking to you lol)
Re: My gt spec
Posted: Mon Nov 21, 2011 5:17 pm
by Dub_Dan
me being the prat i am i would always be using it thinking im out of fast and furious hence why i wouldnt buy it id need an unlimited credit card lol! but fair play for risking it mate as i guess your the only polo tdi owner using it!
