heated wing mirrors
Posted: Tue Dec 13, 2011 8:34 pm
by rover220
does the gti have heated mirrors? if so, mine dont seem to work, is there a common problem that may cause this?
Re: heated wing mirrors
Posted: Tue Dec 13, 2011 8:42 pm
by wackojackso
The GTI does have heated mirrors but you need to have the heated rear window switched on!
Posted: Tue Dec 13, 2011 8:45 pm
by rover220
wackojackso wrote:The GTI does have heated mirrors but you need to have the heated rear window switched on!
mine dont work then.
start the checking with fuses then i guess.
Posted: Tue Dec 13, 2011 9:24 pm
by NotRich
Same fuse system as the rear window.
I'd start by popping the glass out and getting a multimeter across the cables.
