Topping Up Gearbox Oil...
Posted: Mon Jan 23, 2012 6:48 am
by nigelelliott394
I've had a look for this recently and there isn't really a comprehensive guide on how to do this. I'm hoping to have a go at this myself at some stage. Has anyone got any advice or some kind of guide? To be honest, pictures would be really helpful.
I know it's a lot to ask but it may help out other members in future and might be a good thread to pop in to the DIY section
Thanks,
Nigel
Re: Topping Up Gearbox Oil...
Posted: Mon Jan 23, 2012 8:15 am
by rover220
its really not hard, unscrew the filler plug (need 17mm hex key), stick a lenght of hose pipe in the hole and top up through the hose pipe till oil runs out of the hole.
filler plug should be on the front of the gearbox between the 3 torx headed bolts.
Posted: Mon Jan 23, 2012 8:32 am
by nigelelliott394
Sweet
Cheers Rover!
I'll go have a nosy when it gets a bit brighter and take some pictures and maybe piece together a DIY if I decide to have a go at this.
Posted: Mon Jan 23, 2012 11:11 am
by benmkiv
I believe there's two chambers on these boxes? Might be wrong..
Posted: Mon Jan 23, 2012 12:08 pm
by funlovinry
Just make sure you open the filler plug first. Might be a little inconvenient if you can let the oil out but not manage to put the new oil in...
Posted: Tue Jan 24, 2012 10:01 pm
by Bepe
and for god sake dont put it in the flywheel inspection hole, been done before by someone lol
