Lowering front end help??
Posted: Mon Feb 13, 2012 12:18 pm
by Russell9n3
I'm running FK High Sport coilovers and they just run that inch or 2 to high on the front. I've seen other polo's with them on and they seem to be lower than mine at the front end. Any suggestions without cutting any springs? Needs sorting because it looks like its sat on its arse at the moment with the front end a mile in the air aha. Many thanks.
Re: Lowering front end help??
Posted: Mon Feb 13, 2012 1:35 pm
by Dennis
removing helper spring?
that what I'll do when the spring comes on ma ta technix's...
Posted: Mon Feb 13, 2012 8:18 pm
by Russell9n3
May sound stupid but some one else suggested this but i've no idea what this is... is it located within the strut? Because i only see one spring an that is the obviously the big main one.
Posted: Mon Feb 13, 2012 10:14 pm
by Dennis
I have 2 springs on my technix's...think you should have two also...people remove the smaller/shorter one and the adjuster at the back to go lower
Posted: Mon Feb 13, 2012 11:12 pm
by Russell9n3
Alright man ill have a look tomorrow. An yeah i never bothered to put the rear adjuster in so it looks like its sat on its arse too much.
Posted: Tue Feb 14, 2012 2:39 pm
by Dennis
you can also remove the ARB, put shorter droplinks, or remove them completely with the ARB, cut bumstops or get custom, shorter springs etc.
I know that alot of people had done a lot,even all of the above....and then you need a good tyre dimension/wheel width and ET combo and you're done :mrgreen:
Posted: Tue Feb 14, 2012 5:38 pm
by Russell9n3
I've already got shorter droplinks so think i may have to go down the shorter spring route. An yeah i've got a few sets of alloys so got that sorted just need the front end stance sorted. Anyways cheers fella.
Posted: Tue Feb 14, 2012 6:16 pm
by Dennis
no problem!
feel free to post pics when you sort your stance! :D
Posted: Thu Feb 23, 2012 5:08 pm
by jem-9n3
Dennis wrote:I have 2 springs on my technix's...think you should have two also...people remove the smaller/shorter one and the adjuster at the back to go lower
I was thinking of doing this, will this make the ride stiffer or softer? Or is there a difference if you put the helper spring at the top to the bottom? I've seen both ways :s
