Metal clang *fault*
Posted: Tue Feb 21, 2012 9:52 am
by Me9141
I have a 9n 1.4 TDi.
I keep getting this metal clang seems to come from under the car. It sometimes comes from the front or what seems like the middle of the car.
It doesn’t happen all the time but recently it’s been getting worse and happens most of the time.
It occurs when I start the car, when accelerating from a stand still and when I lift my foot off the accelerator as I’m driving.
I’ve asked the local garage a while back to try and diagnose it but it was not as bad then, its recently got way worse. I’ve had a look around and can’t seem to diagnose the problem myself.
Anyone else had similar issue?
Anybody know what it might be?
Any help is much appreciated thanks in advance.
Re: Metal clang *fault*
Posted: Tue Feb 21, 2012 4:50 pm
by g__humm
Could be wishbone bushes or the bottom engine mount.
Posted: Tue Feb 21, 2012 5:43 pm
by K.I.T.T.
Check the front coil springs too. Mine snapped with less than 30k miles on the car. Not that uncommon...
Ash
Posted: Wed Feb 22, 2012 8:20 pm
by Me9141
g__humm wrote:Could be wishbone bushes or the bottom engine mount.
I have had them replaced with brand new VW ones 3 months ago.
K.I.T.T. wrote:Check the front coil springs too. Mine snapped with less than 30k miles on the car. Not that uncommon...
Ash
Had the passenger side replaced a year ago, replaced the whole leg.
But I might investigate the springs again just to see if theres something else wrong there.
Posted: Fri Mar 02, 2012 11:11 am
by Me9141
Have checked the springs and they are all fine.
Seems to be something else as the noise occurs when you start the car also.
Posted: Sat Mar 03, 2012 12:32 pm
by g__humm
Engine mounts?
Posted: Tue Mar 13, 2012 5:16 pm
by Me9141
g__humm wrote:Engine mounts?
That was my initial thought, it seems to come from the bottom of the car so I think it could be the one holding the gearbox.
I will need to get it on the ramp again and have a look at it, as I have not had a chance to get it on a ramp for a while.
Posted: Thu Mar 15, 2012 1:58 pm
by Polo96CL
I have a similar issue with my 9N3 GTi, doesn't happen when you start (and practically disappears when you put cruise control on :? ) but mine is more like a clicking metal noise. Happens when I lift my foot on the acc, over bumps and also if you press the brake then let off. Idea's?
Metal clang *fault*
Posted: Thu Mar 15, 2012 2:10 pm
by benmkiv
My tdi made a metal clang when my turbo blew up :(
Posted: Thu Mar 15, 2012 6:53 pm
by g__humm
Polo96CL wrote:I have a similar issue with my 9N3 GTi, doesn't happen when you start (and practically disappears when you put cruise control on :? ) but mine is more like a clicking metal noise. Happens when I lift my foot on the acc, over bumps and also if you press the brake then let off. Idea's?
Bushes prob mate
Posted: Thu Mar 15, 2012 8:35 pm
by Polo96CL
Got poly bushes in there recently fitted :-S
Posted: Sat Mar 17, 2012 1:34 pm
by Polo96CL
Think I've diagnosed mine, front right lower CV joint. Will make a clicking noise first, then a whiring noise and eventually you'll lose all drive to that wheel as it spins inside itself.
Posted: Sat Mar 24, 2012 1:05 am
by umar-dub
I also have a similar issue with my polo 1.4 tdi. Cars been to a couple of mechanics who can not find a fix. It's a constant clicking noise when the car is started, and upon revving the car the noise disappears, bushes have been changed. The noise comes from the drivers side underneath the car. I reckon it's the fan belt tensioner or some sort of tensioner which makes this metal tick tick noise. Is this a similar issue you having to mate?
Posted: Fri Mar 30, 2012 7:58 pm
by LiamMk6Polo
Try your lower wishbone ball joints. Jack the car up with the wheel clear off the ground. Hit the tyre on the inside of the wheel see if the noise is there then its your bottom ball joint. £20 and a hours labour. So £70 at a dealer dependant on the rates or fix it your self.
Posted: Fri Mar 30, 2012 11:28 pm
by umar-dub
Mine turned out to be the water pump failing.Yesterday it was making some horrible noise when starting.. Got the car towed to a local mechanic which he removed the cambelt cover and he was able to see the water pumps pieces and the belt shredded. Luckily the cambelt never snapped or neither did the timing mess up otherwise that would have been a serious expenditure! So the help of me not turning the key really helped :)
