Headlamp condensaton and contamination
Posted: Sat Mar 10, 2012 5:12 pm
by Craigy
Hi
anyone else with a 6R had condensation in any of their head lights ?
also i have some weird contamination in the area where the side light bulb is. It kind of looks like plastic shaving
i aint even touched the things and the car was a lease car before i bought it
Re: Headlamp condensaton and contamination
Posted: Sat Mar 10, 2012 5:13 pm
by CANDYMAN
Yeah i had condensation in both mine when i picked her up last week. But it has gone now not sure what caused it?
Posted: Sat Mar 10, 2012 6:23 pm
by Craigy
might be wrong but is it not an MOT failure when the time comes ?
Posted: Sat Mar 10, 2012 7:02 pm
by CANDYMAN
I think only if the front lens has gone milky.
Posted: Wed Mar 14, 2012 9:19 pm
by Donny
Only if it affects the beam pattern.
Posted: Wed Mar 14, 2012 9:41 pm
by blazeguarder
Craigy wrote:also i have some weird contamination in the area where the side light bulb is. It kind of looks like plastic shaving
Take off the rubber bulb covers and remove the bulbs themselves, check to see if any of the holes for the bulbs have been enlarged at all. Might have been drilled or similar for the previous owner to fit HID bulbs? Just a thought...
As for the condensation, a mate of mine just bought a new car with xenons. Fogged up completely the first time he used them but cleared and it's never been a problem since. Hopefully its the same case here?
Posted: Thu Mar 15, 2012 11:41 am
by Donny
best way to stop the condensation is to drill a small hole at the top of the headlight casing , ofcourse once you've sorted it out with vw, you'll be lucky if they do anything, my mot tester had a w sharan and he had condensation they just f****d him off, good luck to yourself though tell them you not happy you'll never buy a new vw again and your going to tell as many people as possible, they might just back down, who knows.
Posted: Sun Mar 18, 2012 8:33 am
by Craigy
Will know on Monday if it's being fixed. If not I will sort it my self
Problem is that those marks are dry not wet. So they won't go away without wiping
Posted: Fri Mar 23, 2012 6:16 pm
by Craigy
Well after ALOT of fighting with Arnold Clark and speaking to VW customer services it's being replaced free of charge but not under warrenty
Work that one out if you can lol
Anyway should be getting done tue or wed
Posted: Fri Mar 23, 2012 7:30 pm
by The Sheriff
Good result !
