Suspension please new urgent!
Posted: Thu Apr 05, 2012 1:48 pm
by Russell9n3
Putting standard suspension back in, all fine about from the drivers side front. I cant seem to get the bit where the bottom of the arm in to go low enough so i can get it back in... Sorry dont know the technical terms. Would appreciate some help because my anger is getting beyond belief at this point ha
Re: Suspension please new urgent!
Posted: Thu Apr 05, 2012 5:53 pm
by g__humm
Take some pictures of the parts as so we can get a better idea.
Posted: Thu Apr 05, 2012 5:58 pm
by kc
3 bolts for the lower arm off, driveshaft nut out, pull out. hammer time!
Posted: Thu Apr 05, 2012 8:38 pm
by BennoGTi
The only way I could do it is by jacking the suspension arm up (mount the jack under the plate where the bottom of the spring sits with a bit of wood)
Fix the 3 bolts up at the top of the suspension under the bonet, jack the suspension up untill it is raised high enough to get it into the bottom section
Posted: Thu Apr 05, 2012 10:12 pm
by Russell9n3
I solved it in the end. I took the 3 bolts off the lower arm an like you said i then had some hammer time! haha
