UK-POLOS.NET - THE VW Polo Forum • Airbag light on. 6n2
Posted: Tue Apr 10, 2012 4:04 pm
by Kaffrinnn1
I have a 1.0 6n2. Had to take the steering wheel and the dash out to change my pedal box. Since putting it all back together my airbag light has come on. Everything's plugged in, just can't figure out why it's on. Help!!!
Posted: Wed Apr 11, 2012 7:31 pm
by benmkiv
The code probably just needs clearing with vag com. Even if everything's been plugged back in if the ignitions been on while the bags been out or not connected properly will need clearing. Also if you've driven it and not centred the slip ring properly you may have snapped the copper coil in here which also happened to me: try wiping the code first.
Re: Airbag light on. 6n2
Posted: Thu Apr 12, 2012 11:06 am
by Kaffrinnn1
Ah ok. The battery was disconnected the whole
Time the airbag was off but ill try that. Cheers! :)
