9n3 Polo headlights - user replaceable?
Posted: Fri Apr 13, 2012 12:56 am
Hello.
First an apology for my lack of knowledge and for posting what I assume a fairly basic question - you guys are the experts so I figured it worth asking before either creating a problem myself or spending way more than necessary in a garage...
Basically one of the dipped headlight bulbs in my 2007 9n3 Polo has blown as they occasionally tend to do, so obviously needs replaced - for the quick question, is this a user replaceable part?
The manual gives a very simplified explanation, but also tells you to take it to an official technician, and from what I can gather replacing a bulb can vary from incredibly easy to virtually impossible depending on your car model and skill level. I will be the first to admit I am not really particularly skilled or knowledgeable in this area (hence the post here) beyond the basics like swapping a wheel and checking the various fluid levels, though like to think myself moderately capable with the correct knowledge. Is the average person like me going to be able to swap out the bulb without too much swearing and disassembly, or is it worth taking it to my local garage and asking for their help? Following on from that, if it is doable, how? Searching the internet (and this forum) hasn't seemed to bring up too much of relevance given the huge variety of different models, and the only specific guide I came across has dead links for the pictures that used to be the main part of said guide...
So any opinions on here I stand? Doable by your everyday man or worth a trip to the garage?
Most importantly thank you for any help you can give me and for humouring the inexperienced, much appreciated.
