Polo 6N2 Roof Runners?
Posted: Sun Apr 15, 2012 5:26 pm
by bewsh
The picture above isn't of my car but I found this on eBay. But I have the same problem as in the picture, paint is starting to flake off the roof side runners (if that's what they're called?). Question is, are these part of the roof or can they be removed/replaced? If so, does anyone know how to remove them? Or would it just be easier to get them sprayed?
Thanks.
Re: Polo 6N2 Roof Runners?
Posted: Thu Apr 26, 2012 7:53 am
by fonzooorooo
They're normally removable so you can fit roof bars. That could be what's causing the paint to flake - if they've been bent/twisted/mangled trying to remove them. You're likely to have to pull them toward you at the end before you can lift/unclip them along their length. Saying that, I've no specific knowledge of the model - it's simply what I'd expect from that type of trim. (from experience it's like that on sciroccos, old passats and rovers)
Posted: Thu Apr 26, 2012 6:42 pm
by bewsh
Excellent, thanks for the reply. I will try and remove them, and get second hand ones or if they are removable, it would make it an easier job to re-spray!
Posted: Tue May 01, 2012 8:21 pm
by Verity
I took mine out to clean underneath
they are just held on with little black clips
Get a screw driver (with cloth rapped around it) and pry it up at one end. Then just carefully pull up and wiggle a bit and it should pop off bit by bit
Posted: Fri May 04, 2012 12:30 pm
by bewsh
Awesome, thanks alot!
