UK-POLOS.NET - THE VW Polo Forum • Yellow DV spring needed for stage one remap?
Posted: Fri May 04, 2012 6:19 pm
by lee gti 88
AS it states really, im going in for a remap tomorrow, currently running a forge dv007p with a green spring. after the map will i need the yellow string to maintain boost in the dv? :?
Re: Yellow DV spring needed for stage one remap?
Posted: Fri May 04, 2012 6:54 pm
by Gillen
Correct 8)
Posted: Fri May 04, 2012 7:03 pm
by lee gti 88
Cheers dude, will I be ok with the standard one until I can get my hands on one? any ideas where is the best place to get one?
Posted: Fri May 04, 2012 7:35 pm
by 9N3 Turbo
For stage one green is what you need. Forge sell the spring kit.
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
http://www.forgemotorsport.co.uk/conten ... ct=FMDVTUN
Posted: Fri May 04, 2012 9:12 pm
by Gillen
A lot of people seem to use the yellow :?
Posted: Fri May 04, 2012 9:16 pm
by 9N3 Turbo
Gillen wrote:A lot of people seem to use the yellow :?
Stage two for yellow. On stage one I would say its to strong.
Up to each individual I suppose.
Posted: Fri May 04, 2012 9:30 pm
by Gillen
Yeh I suppose it'd be wise to go with what forge recommend!
Posted: Fri May 04, 2012 9:33 pm
by 9N3 Turbo
Gillen wrote:Yeh I suppose it'd be wise to go with what forge recommend!
That's what I did. Don't want to cause unnecessary stress to the turbo :mrgreen:
Posted: Sat May 05, 2012 12:02 pm
by lee gti 88
Cheers for that guys, Just had it mapped seems fine on the green spring tbh. more than chuffed with the results :)
Posted: Sat May 05, 2012 4:58 pm
by Gillen
Sounds good, which software did you go for?
Posted: Sat May 05, 2012 7:37 pm
by Crippin
I need my mapping. Where did you go?
I've had nothing back from jabbasport.
Posted: Sun May 06, 2012 8:37 am
by g__humm
Use r tech he can give u launch control.
Posted: Sun May 06, 2012 11:58 am
by lee gti 88
I went for a more bhp remap. I can not fault it at all! It pulls like a train could instantly tell a massive difference. The car pulls from low revs all the way up to the red line now. Jason logged the info on a drive round and said my car was pulling around 1.1/1.2 psi or bar? As apposed to 0.6 standard.
I did also notice on the drive back home down the M6 that my mpg was increasing and what was with a good few blasts to test it out! :D
