Polo 9n lumpy idle on start
Posted: Sat May 05, 2012 1:17 pm
by Flattley3
Hi, I own a polo 9n 1.4 16v 53 plate. I've been having a lumpy start up on the car and was wondering if anyone knew what the problem is. It starts then the revs drop off as if it's going to stall and does that three or four times then settles down. I've looked at a few things but can't seem to find or solve the problem. I also have noticed a little judder at around 2k revs in second and third gear don't know if this is linked.
Thanks.
Re: Polo 9n lumpy idle on start
Posted: Sat May 05, 2012 3:38 pm
by Bickerton
I'd try and get it scanned on vagcom as sounds a lot like a a sensor like icv or coolant temp sensor. Have you noticed your fuel consumption going up?
Posted: Sun May 06, 2012 7:12 pm
by Flattley3
Does seem abit thirsty nothing major though. I'll get it scanned see what it says. Cheers
Posted: Tue Jun 05, 2012 4:34 pm
by Flattley3
I've had it hooked up to a computer and got these codes 17989, 17952, 17580, 17962. All relate to the icv which I've had off and cleaned as I read that it can get rather clogged up but that doesn't seem to of done anything. Any more suggestions is the icv on the way out?
Posted: Wed Jun 06, 2012 6:44 am
by Flattley3
i had the codes erased now it seems worse than ever its idling at around 1100rpm until it warms up then sits at 900rpm which is more than normal and it seems thirstier than ever. help!!!
