What Bushes?
Posted: Mon May 31, 2004 11:19 am
I put this in the G40 section, but I thought Id put it in here as more people look here:
Does anyone reccomend or have any advice for bushes on a G40? mine are shagged. the passenger wheel moves backward a little when you tighten the wheel up and the drivers side wheel sits further back than the passenger side
So I want to change the lot. Is it an easy job? is there any special alignment that needs to be done,etc? or can it be done on my drive by myself?
I think I may go for those cheaper ones that i found on google, but they haven't got back to me with the info yet as theres a few choices of arb diameter and then meatl bushes or something (similar to powerflex)
http://www.powerflex.co.uk/products.asp ... talog=0537
Adobe Acrobat File: http://www.superflex.co.uk/SuperFlex_Vo ... Prices.pdf
I know that the number 3 ones are franked, I was told the wheel movement was probably number 1's and I thought that if its gotta be pulled apart, I may as well do the number 2's as well. But that's where the metal thing comes in. Whats it all about? Anyone know?
