QUESTION ABOUT AUTOMATIC TRANSMISSION
Posted: Tue Jun 01, 2004 4:22 am
Hi, I'm a new Polo user, and just got a 1.4 with automatic transmission (2nd hand, 2002 made).
Noticed some 'strange' behavior with the automatic gearbox :
1. If the car is in 1st, 2nd and 3rd gear, whenever I release the gas pedal, the engine speed will drop close to idle, and the car will basically feel 'rolling free' very smoothly. If I accerlerate again, the engine will simply rev up to the necessary speed.
2. However, if the car is on the 4th gear, usually travelling at close to 60mph, if I release the gas pedal, the engine will not drop to idle. It seems the engine is now 'locked' to the wheels, just like a normal manual transmission. Since the car is now off the gas, the engine speed will drop by around 500rpm, and the car will feel being pulled back suddenly (just like what will happen with a MT at 1st or 2nd gear). Although such engine brake is not very apparent, I'm not sure why the huge difference from the first 3 gears, and if it is a problem with the AT.
Anybody knows if this is normal?
