Gearbox Trouble, Anyone else had this problem?
Posted: Thu Aug 23, 2012 1:33 pm
Hey guys, I got a Polo 6N2 (1.4 16V) and recently after long drives my gears get really stiff when changing from 1st to 2nd a lot of the time. 1st and 2nd are probably the worst gears to get into and when putting the car into reverse it doesn't just slip in like usual, now it makes a horrible grinding noise when it goes into gear! (can't stand it!)
I already got the car checked out at a local clutch and gearbox centre and he said that he couldn't see any problems with it, can you top up the gearbox oil at all or something?
Just need to lube up the gears and get it back to normal.
Let me know if anyone has had the same problem or if anyone knows how to resolve this!
Jamie
Jamie
