fault codes for coil pack query
Posted: Fri Sep 28, 2012 8:58 am
So... yesterday it ran ok. Today its on 2 cylinders (out of 3) ... The car's a '03 AWY on 85K
Fault codes are:
16804 - Catalyst bank 1 below threshold
16685 - Cyl. 1 Misfire
17658 - Fuel level too low
The way I see it, is that the fuel level thing's a lie (that's sender unit related, right?)
then cyl. 1 isn't firing, leading to the cat showing below threshold.
My mind went straight to coil packs, as it's not had any yet, and from what I see on the forums, they're prone to failure.
It's had a throttle body, temp sender, plugs are only (just over) a year old.
I'll whip the plug out later, to test if it's firing... can't do it right away as my small plug spanner's gone walkies..
Is this thought process miles off, or should I really be looking at fuel and vacuum?
Fault codes are:
