6n2 gti alarm issue
Posted: Sun Nov 25, 2012 11:22 pm
by eyaaz6n2
Hi ive got problem with my alarm i lock the car will be fine few mins later alarm goes off unlock and lock again then same thing last night had to disconnect battery dont know what wrong with it any suggestion
Re: 6n2 gti alarm issue URGENT
Posted: Mon Nov 26, 2012 3:08 am
by eyaaz6n2
Car battery is new and also changed the key batteries but still no luck need help asap have to disconnect once parked otherwise alarm keeps going off
Posted: Mon Nov 26, 2012 5:50 am
by rover220
Does your interior light work properly?
I would disconnect the alarm siren. Its under the scuttle panel on drivers side. You can get you hand to the multi plug wthout having to remove the panel too
Posted: Mon Nov 26, 2012 10:23 am
by eyaaz6n2
Yes pal light does work but i keep it turnd off
Posted: Mon Nov 26, 2012 10:38 am
by eyaaz6n2
Posted: Mon Nov 26, 2012 8:08 pm
by eyaaz6n2
What does the alarm socket look like theres a few down there
Posted: Mon Nov 26, 2012 8:10 pm
by rover220
There's only one. Can't miss the siren
Posted: Mon Nov 26, 2012 8:26 pm
by eyaaz6n2
On myn havent got any covers so can see all diff pins confused
Posted: Tue Nov 27, 2012 2:17 pm
by eyaaz6n2
Fault interior motion sensor disconnected for now
