Camber adjustable top mounts
Posted: Thu Dec 06, 2012 1:00 pm
by chewy_
Anyone know where you can get camber adjustable top mounts or coilovers with camber adjustable top mounts for the 9n?
MY camber is all over after lowering and the car pulls to the left quite badly.
Re: Camber adjustable top mounts
Posted: Thu Dec 06, 2012 3:32 pm
by g__humm
Get the tracking done. U get a small amout of camber on the two bottom bolts. Adjustable top mounts are very expensive. Kw do them at £200+ I believe.
Tracking will stop it pulling.
Posted: Thu Dec 06, 2012 9:32 pm
by chewy_
Tracking has been done but it still pulls. The print out shows the camber is out a lot more on one side than the other hence the pull. It pulled slightly when I bought it but since it's been lowered it's now worse. I'm guessing they've hit a curb and bent something before I bought it.
I've just read that apparently camber is adjustable as the standard top mount is offset, so just undo the 3 bolts, jack the front to unweight the suspension, stick your hand under and twist it round , you have 3 choices of camber setting?
Kw only fit KW coilovers. I've found a company in Australia (K-Mac) that do them for around £350 for that price I may as well get some D2 racing coilovers which are damper and camber adjustable.
Posted: Tue Dec 11, 2012 8:23 pm
by mark03polo9n
you can adjust your camber slightly where your strut bolts to your wheel hub by loosing off the bolt and pushing the hub either up or down depending on whether or not you need more positive camber or more negative camber. baring in mind that there isnt to much movement there so if this isn't enough then as you said there is probably something bent and you should check further for damaged components rather than replacing parts for more adjustable ones which can cause more cost and time than you may need
Posted: Thu Dec 13, 2012 11:08 am
by RUM4MO
The camber adjustment bolts are only applicable to 6N Polo and 6K Ibiza etc. The 9N Polo Fabia 1 and Ibiza 6L just have a clamping socket at the lower end of the damper/strut.
One way to sort the side to side difference is to move the lower subframe across the car to equalise the camber. To correct the camber without buy expensive adjustable top mounts, you would need to open up the holes in the TCAs where the lower swivels connect to the TCAs and fit thick washers or plates over the enlarged holes, then weld these plates to the TCAs to close the bolts back down again after sorting out the camber.
I've not needed to do this, but have read of others doing this mod.
As the original top mounts have three fixing holes, and they are not as far as I know eccentric, rotating them will have no useful effect. Now if these top mounts were eccentric, rotating them could improve camber and really mess up caster - think about it!
