Polo 6N2 GTi Overheating Problem
Posted: Sun Dec 23, 2012 11:32 am
Hi guys, hoping you can help.
I've got a 51 plate Polo 6N2 GTi with around 58k on the clock. Got a problem with the engine overheating intermittently with the overflow tank boiling/steaming and spewing out coolant. It seems to only happen idling sitting in traffic however the fan is kicking in.
I've had the thermo and housing replaced and also I had to replace the Rad hose as it had split at the join between the top and bottom hoses. They also both get hot with the engine running so I guess that rules out a problem with the Water Pump which was replaced at 40k along with the cambelt. Yes/No?
One thing to note is the temp gauge on the dash is a bit erratic. It stays on cold most of the time, may jump up to normal then go back to cold but it always jumps into the red and the dash lamp comes on when the engine is overheating. Is this a problem with the temp switch but doesn't this switch just control the dash gauge and nothing else? I.e nothing to do with regulation of the engine temp itself.
I have been told that because the Rad hose had blown it maybe an issue with the head gasket due to the pressure build-up in the hoses. Is this correct?
What do you guys think?
