Page 1 of 2
Stiff gear changes
Posted: Fri Jan 04, 2013 9:17 am
by 6n2stan
The Polo has sat for nearly two weeks over Crimbo as we've gone everywhere in the Family car.
I come to use the Polo on Wednesday and think the gear stick is a bit stiff but put it down to using the Golf which is only 4 years old with 50k on the clock. Then the wife drives the Polo yesterday and says the same thing and today I'm back in it and it is stiff end of!
I haven't checked the oil yet but there's no leak on the garage floor. Is it a fill to spill 'box?
It isn't any noisier than before Crimbo and it still engages the gear fine. In neutral it feels normal and it doesn't free up anymore after my 30 min, 22 mile commute.
My main concern is I'm off to France tonight (in the Golf) for a week leaving the wife and 2 kids the GTI here, will it last? Linkage problem?
BTW it's an AVY 2000MY with 145K on the clock and the original 'box
Re: Stiff gear changes
Posted: Fri Jan 04, 2013 10:05 am
by alexperkins
It is a fill to spill box
Its likely its a linkage problem. Its certainly done some mileage, so the bushes on the ends of the shift cables may have disintegrated over time
It wont die, but its something you need to look at.
Posted: Fri Jan 04, 2013 10:56 am
by 6n2stan
Cheers Alex,
I haven't got a Haynes manual for it so can't picture it, is it the same as any 6N2 or is it another GTI specific bit? Is there a nylon cup below the gear stick that can wear too?
Posted: Fri Jan 04, 2013 11:01 am
by alexperkins
Its the same on all the 6N2s - same shift mechanism
There is, but that generally doesnt wear. Its likely to be the gear shift end thats worn.
Posted: Fri Jan 04, 2013 11:50 am
by 6n2stan
alexperkins wrote:Its the same on all the 6N2s - same shift mechanism
Big job with oil draining out or fairly straightforward? Would you go with OEM parts or is aftermarket OK?
Posted: Fri Jan 04, 2013 11:57 am
by alexperkins
Always use OEM in my opinion
Either that or Castrol Syntrans 75w-90 Mutlivehicle
It has to be a synthetic oil regardless of what anyone tells you - alot of places beleive semi synthetic is suitable
Not too hard. Remove drain plug, drain oil, fill up, done.
Posted: Fri Jan 04, 2013 12:40 pm
by 6n2stan
OK cheers, I'll look into it when I get back week after next if it hasn't given up the ghost in the mean time on the wife!
Posted: Fri Jan 04, 2013 2:31 pm
by alexperkins
Before you do oil, check the linkages though. No point changing the oil if it doesnt need doing!
Posted: Fri Jan 04, 2013 2:46 pm
by 6N2 GTI 00
If memory serves the box holds 2.8 litres so just make sure you get enough
its about £18-20 for 3 litres from Volkswagen
I dropped the oil twice on mine and used the OEM stuff first time round but second time opted for Millers 75W90 fully synthetic which is top quality stuff
Posted: Fri Jan 04, 2013 2:49 pm
by alexperkins
It actually depends on the build date Ben
Some are 3.2 litres depending on the build date! Just to confuse matters. If you PM me your reg number Stan I should be able to tell you which it is
Millers, OEM or Castrol are all good and fully synthetic
Halfords sell the Castrol Syntrans on the shelf, and VW generally stock their own stuff on the shelf.
Posted: Fri Jan 04, 2013 2:52 pm
by 6N2 GTI 00
Thats good to know mate, why is the capacity bigger on the later models?
Mine was a 1999 V so 2.8 was spot on
Posted: Fri Jan 04, 2013 2:55 pm
by alexperkins
Mine was 3.2 and a 2000, but mines a crossover to complicate matters even more! lol
Posted: Fri Jan 04, 2013 2:59 pm
by 6N2 GTI 00
Good job you worked for Volkswagen mate otherwise this forum would be struggling for information
Posted: Fri Jan 04, 2013 3:02 pm
by alexperkins
Haha it would
Too much knowledge...but hey knowledge is power
Posted: Fri Jan 04, 2013 8:48 pm
by Verity
Gear linkage went on my car last year. Since having it done my gearbox has been like a dream! Goes into gear so smoothly. I never even thought my box was that bad, but it just made such a huge difference!
