UK-POLOS.NET - THE VW Polo Forum • Polo 9n1 1.4 TDi Coolant temperature sender
Posted: Sat Jan 05, 2013 4:05 pm
by akz786
Hi
Was looking for a DIY on this and could not find it on the 1.4 Tdi 9n1? - I seem to have located it on the right hand side of the engine facing in from the back somewhere, seems really difficult to get too. I will need to remove pipes around MAF airbox area...
I think I could just pull the horseshoe clip out and the pull the electrical connector off and replace?
All help appreciated
Re: Polo 9n1 1.4 TDi Coolant temperature sender
Posted: Mon Jan 07, 2013 5:06 pm
by fonzooorooo
can't tell you where to look on your engine, but yes to the method - unplug, unclip, pull out, (don't forget O ring seal!) new one in, clip back in, plug back on. On the petrol, you have to plug diagnostics in to "tell" it you've changed it. I presume the TDI needs the same.
