UK-POLOS.NET - THE VW Polo Forum • Changing Fog Lights Polo 6R
Posted: Sun Jan 06, 2013 9:28 pm
by JCT 1991
well this may be slightly abstract but ive found it to be less difficult to use a old hanger to pull the trim off as the one supplied by VW is a bit of a pain.
this is the trim once out
and here are the where all the clips are
this is the view you should have now the two screws need removing this can be done with a T27 bit or the VW tool supplied
ta daa light out
now just unclip the power supply and twist the fitting out anti clockwise
changing the old halogen gas bulbs for some nice new LED ones
always best practice to check the bulbs with the power supply before refitting everything to the car potential time saver if somethings not right.
So then do this Process in reverse to achieve the next step
Fog lights in and working
Jobs a Gooden hope this helps
Re: Changing Fog Lights Polo 6R
Posted: Mon Apr 27, 2015 10:50 am
by dillo161
Hello mate,
Could you please post a link to the LED Daytime Running Lights? I am assuming you have got these in a white/blue colour. Thanks.
