UK-POLOS.NET - THE VW Polo Forum • Had my polo for a month and having a few problems!
Posted: Tue Jan 22, 2013 4:58 pm
by Golemsmate
Does anybody know an easy way to find out when my car was built? I keep seeing polos in front of me with their exhaust hidden but mine sticks out on the left hand side. Is the hidden exhaust a feature from the earlier or newer polos? Or is it merely because they're 1.2s and mine is a 1.4?
The reason I ask is because I bought the 2012 plate polo in December but I'm experiencing a few faults that I have seen on this forum to affect 2010 plates. I'm beginning to worry that mine is an older version that was registered later. The problems I'm having are:
- indicator failure light has come on twice in two weeks. First telling me my right one is broken and the second time the left one. Both of which went off after turning the ignition off. If it goes in to the VW garage, would they have a record of the fault on the PC?
- There is a knocking noise when I go over anything larger than small speed bumps, even at very slow speeds. This can be intermittent, so knowing my luck it won't do it for them.
- The door handles are quite stiff and difficult to pull open.
It's due to go in later this week, so I'll find out what they think. Hopefully they already know about the issues!
Re: Had my polo for a month and having a few problems!
Posted: Tue Jan 22, 2013 5:24 pm
by Golemsmate
Thought I'd add a photo of my car!
Posted: Tue Jan 22, 2013 6:18 pm
by DubbisH
I might be wrong on this but im sure higher spec models like the SEL have the exhaust coming through the bumper on the left.... the other bits and bobs dont seem like there too major so your doing the right thing by giving it them to look over again for you.
*DubbisH*
Posted: Tue Jan 22, 2013 6:46 pm
by jimbo_tdi
They 1.4's, R-Line and SEL's have the single exhaust pipe showing, I like it, it breaks up the back abut, you can get an A3 trim to go over it which has a chrome effect... If you don't like it then you can always swap bumpers with me! ;) the other problems I can't help you with, you could try some lubrication spray like WD40 or whilst it's in the garage ask them to put some cylinder lock spray in for you.
Posted: Wed Jan 23, 2013 11:06 pm
by Golemsmate
Car is going in tomorrow morning, will report back if they find anything :)
Posted: Fri Jan 25, 2013 4:07 pm
by Golemsmate
indicator problem was fixed through a software update (sounds really weird saying this in relation to a car)
all the door handles were lubricated and they feel much better.
And most importantly they couldn't diagnose the knocking noise but they removed the top link, cleaned them up and fitted them again. But they've said come back at any time if the noise happens.
Posted: Sat Jan 26, 2013 8:56 am
by john.p.clegg
"Does anybody know an easy way to find out when my car was built? "...it's on the vin plate..
John :wink:
Posted: Sat Jan 26, 2013 11:58 am
by Golemsmate
@john.p.clegg - Cheers, looking online it says the 10th says the year. Mine is C, little bit confused but does that mean it was built in 2012? Quite surprised as it is a 12 plate.
Cheers!
Posted: Sat Jan 26, 2013 3:45 pm
by jimbo_tdi
http://www.clubvw.org.au/vwvin - according to that it was built in 2012...
Posted: Sat Jan 26, 2013 7:19 pm
by Golemsmate
And built in South Africa! Had a quick trip from being built and then registered in Feb!
Posted: Sun Jan 27, 2013 12:28 am
by jimbo_tdi
Mines the same, it was registered March 2011 and was made in 2011 :D
Posted: Tue Jan 29, 2013 8:17 am
by PogoCT
Golemsmate wrote:And built in South Africa! Had a quick trip from being built and then registered in Feb!
We pump out these polos like nobody's business :lol:
Posted: Tue Jan 29, 2013 10:59 pm
by Golemsmate
@pogoCT - its actually quite impressive!!
& the mysterious knocking noise might be solved. My brother (in the dark) saw that the air conditioning pipe was knocking against the side of the bonnet. Just had to shift the rubber protector along. Yet to go over any bumps but I'm trying to be positive!
Posted: Wed Jan 30, 2013 9:51 pm
by jakovdub
I've got the audi a3 tip on mine, can't really tell in this picture though but it's the only one i got of it, just looks good and thickens the exhaust and alsi in a chrome finish, can't even tell its a tip as no clamps are visible :)
Posted: Thu Jan 31, 2013 3:10 pm
by Golemsmate
@jakovdub finally got round to taking a picture, mine seems to look quite similar to yours. I assume the current exhaust is standard on mine.
