As the title says,and it stopped working,looking at the Haynes manual was Bobbins....remove the 9N front grill and bumper-totally different to the 9N3,so after taking out all the torx screws I could see,and then putting them back in again removed the front of the inner wheel arch cover and a bit of the front undertray...I can see the pump and it works O.K. using my beloved for what she does best,playing with the knobs, tracing the squirting to near the ABS pump unit....what a cow..just behind,under the wiring loom is the pipe which feeds the rear screen....AND IT'S GOT A JOINT IN IT...don't get too excited there's no Marijuana round,just an in-line push fit connector which had come off....it's not easy to get your fists in there but with a little patience can be done...
John
9N3 rear screen wash
Re: 9N3 rear screen wash
If its the same as the 9n they can drip onto the electrical connections below and give a bad circuit. When I bought my 9n the rear washer and wiper didn't work. Traced it to corroded terminals in the boot. Jobsagoodun
Sent from my HTC Incredible S using Tapatalk 2
