UK-POLOS.NET - THE VW Polo Forum • Adding sub and amp to RCD510
Posted: Tue Feb 26, 2013 3:34 pm
by adzmofo
Hello!
I'm looking to install a sub and amp to my 2010 Polo GTI. I've currently got the RCD510 head unit with everything else standard. Is there a line out from the head unit i can run to the amp in the boot or will I have to do some modifying and take a feed from one of the speaker outs?
I'd like to keep everything as standard as possible but just with the extra bass :)
Re: Adding sub and amp to RCD510
Posted: Thu Feb 28, 2013 11:36 am
by alexperkins
Youll need to use a high level convertor/line out to get an RCA for a preout - I had to do that on my RNS510.
One of these http://www.halfords.com/webapp/wcs/stor ... yId_265889 will do the job nicely.
Posted: Fri Mar 01, 2013 9:26 am
by ripper0306
Alex, with that, you don't have a remote to shut down the amp ?
Posted: Fri Mar 01, 2013 10:13 am
by alexperkins
On the golf, I took a feed for the remote wire from the boot 12V socket which was ignition powered so it wasn't an issue
There's nothing to stop you running a seperate remote wire to an ignition switched live :)
Posted: Wed Apr 03, 2013 5:15 am
by Gigitt
The RCD510 and the RNS510 can have the Speaker wires set to LINE OUT via VAG-COM (VCDS) (www.Ross-Tech.com)
You just have to wire up RCA cable and connectors to the speaker wires - best to do this via a plug-n-play harness so you don't cut the original wires.
