UK-POLOS.NET - THE VW Polo Forum • Fault Code 17549- help please
Posted: Fri Mar 01, 2013 7:42 pm
by WSMRT18
I have a 2000 6N2 Gti on 115k miles with fault code 17549,
I have searched the code and found this information:
Possible Causes:
Mass Air Flow Sensor (G70) OR Manifold Pressure Sensor (G71) faulty
Vacuum Lines faulty
source: http://wiki.ross-tech.com/wiki/index.ph ... 141/004417
I have little experience checking for vacuum leaks but i dont think I there is one, are the MAF sensors known for needing replacing or could it be the maifold pressure sensor?
Any one had over come the same problem before?
Re: Fault Code 17549- help please
Posted: Fri Mar 01, 2013 8:24 pm
by WSMRT18
Turns out it doesnt have a MAF sensor but a MAP sensor, i'll give that a clean.
Posted: Sat Mar 02, 2013 1:25 pm
by alexperkins
Check the Brake servo hose isn't split. It's a common problem on the polos.
Posted: Sun Mar 03, 2013 1:21 pm
by WSMRT18
Thanks Alex,
I have had a look and it does not seam to be split anywhere, the car idles fine but hesitates/stumbles under load and heavy accelaration.
Might have to take it to a garage which is annoying because I like sorting things out myself.
Thanks again helpful as always :)
Posted: Sun Mar 03, 2013 2:04 pm
by WSMRT18
UPDATE:
Just found a vacuum leak on the brake servo vacuum hose, the actual hose isnt split but this connection somehow got damaged and has a hole in...
Posted: Sun Mar 03, 2013 2:21 pm
by alexperkins
That should have a little cap on it but looks like its been snapped off
Vw sell the pipe as a new section and its not much.
Posted: Sun Mar 03, 2013 2:31 pm
by WSMRT18
Thanks will give them a ring tomorow, not sure how it could have been snapped off dont think i have ever had to do anything towards the rear of the engine bay!
Posted: Sun Mar 03, 2013 2:38 pm
by alexperkins
It's probably been broken for some time! Careless mechanics most of the time.
Posted: Fri Mar 08, 2013 2:50 pm
by WSMRT18
Just picked up the new vacuum hose off vw, should there be a cap or some kind of hose that goes on the end of this?
Sorry if thats a stupid question, thanks
Will
Posted: Fri Mar 08, 2013 3:08 pm
by alexperkins
A little green cap. You may need to buy it seperately.
