UK-POLOS.NET - THE VW Polo Forum • 6n2 16v engine cutting out under high revs
Posted: Mon Mar 04, 2013 7:18 pm
by flyluna
Hi im new on hear, Im wondering if anyone could shed some light on this problem for me. I have a 6n2 16v and it has a fluctuating idle and sometimes when its in high revs when driving it will cut out and stop and I have to start the engine again. The engine management light comes on and off on the dash from time to time. The advice that I have been given so far is that its is probably the throttle body. I was wondering if anyone else has had similar issues and has resolved them.
Re: 6n2 16v engine cutting out under high revs
Posted: Tue Mar 05, 2013 9:05 am
by alexperkins
Welcome
First port of call is clean the throttle body with a carb/intake cleaner spray
Check the brake servo hose for splits also
Check the crankcase breather hose is clean
Check the airfilter is clean
Check when the fuel filter was last replaced.
Posted: Tue Mar 05, 2013 7:42 pm
by flyluna
Hi, Thanks for the advice I will check all these things.
