Page 1 of 3
Polo 6R Stalk set Trip Computer
Posted: Sat Mar 23, 2013 9:26 pm
by Eddie-gt
I have for sale a stalk set that was removed from a 2013MY R-Line due to Cruise Control retrofit
This will only fit cars that were built 2013 MY onwards
Stalks consist
LEFT
Indicator and main beam control
RIGHT
Trip Computer Control (rocker and ok button)
Rear Wiper Control
Front wiper Control
£25 Delivered
Re: Polo 6R Stalk set Trip Computer
Posted: Wed Mar 27, 2013 9:23 pm
by Eddie-gt
No one interested?
How about £25 Delivered
Can help with fitting
Posted: Mon Apr 01, 2013 2:32 pm
by Eddie-gt
going on ebay soon
Posted: Sat Apr 06, 2013 1:04 am
by vwpolo16v
Hi Eddie,
I might me interested if you still have it.
Just got a 1.4 SE 6R for the wife.
It does not have a trip computer.
If I add this stalk, will it enable trip computer ?
If yes, are there guides/write-up to show how to do it ?
Cheers,
Mac.
Posted: Sun Apr 07, 2013 12:43 am
by Eddie-gt
Hi
I still have the stalk set
It is a good question, I know on a T5 van by adding the stalk and coding brings up the trip computer on them. Must be worth a gamble at £15
Ed
Posted: Fri Apr 12, 2013 4:05 pm
by vwpolo16v
Hi Eddie,
Sorry mate I missed your reply.
Just looked at how to replace the stalk.
Seems quite involved - especially all the warnings I read about keeping the "airbag coil slip ring in tact" - what ever that is :roll:
So I thought if I was to take it all apart, I might as well look at doing the cruise retrofit at the same.
Theory is if I get this, then I would get the cruise and trip computer.
You did this am I correct ?
Posted: Fri Apr 12, 2013 4:41 pm
by Eddie-gt
Taking the steering wheel off and the slip ring is easy. The slip ring has a 0 degree marking so that is where it should be when you take the wheel off.
Cruise is a big job with a lot of wires to run to the BCM, with hardly any room to work. And one wire needs to go to the ECU which is secured with anti tamper bolts. Not for the novice
If you want Cruise you will need a stalk set with Cruise, hence why this one was removed
Posted: Mon Apr 15, 2013 7:28 pm
by vwpolo16v
Hi Eddie,
Got a mechanic who can help me. Has the right tools and access to VAS coder.
Do you mind sharing the wiring requirements (pin to pin) ?
Posted: Mon Jul 29, 2013 5:58 pm
by cabbage_gti
Firstly sorry for bringing up an old post and secondly did this work?
Were you able to just fit the stalk with trip computer buttons and enable it in VAG-COM to a Polo 6R that doesn't have the trip computer?
Posted: Tue Aug 13, 2013 1:42 pm
by RayC
interested if this didnt sell yet
Ray
Posted: Mon Feb 24, 2014 5:22 pm
by Eddie-gt
Still available
I can include the wires needed to the cluster
I can also fit and code it
Posted: Mon Feb 24, 2014 5:45 pm
by cabbage_gti
Eddie-gt wrote:Still available
What wiring/coding needs doing? I thought it was just a straight swap? One stalk with no trip buttons for one with buttons?
Posted: Mon Feb 24, 2014 7:59 pm
by Eddie-gt
3x wires need to be added to the plug that clips into the stalks and they go to the cluster plug
Coding wise MFA has to be ticked in the cluster
Posted: Mon Feb 24, 2014 8:20 pm
by cabbage_gti
Is this easy to do? Would I need to remove the cluster? Is there a wiring diagram for this anywhere?
Posted: Mon Feb 24, 2014 10:14 pm
by Eddie-gt
I will provide instructions
what year is your polo?
