What alloys will fit?
Posted: Fri Apr 26, 2013 2:17 pm
by Match
Noob question I know but :roll:
So I know my polo is 5x100 but not much else. So when I'm looking for wheels on ebay, do I just need to look for 5x100 and then check the offset (is this what et35 means for example?)
For instance, if I find some Subaru wheels which are 5x100, will they fit? :| Thanks!
Re: What alloys will fit?
Posted: Fri Apr 26, 2013 2:59 pm
by C17LJR
Subaru wheels will fit pcd wise as you say, they are 5x100. Although the centrebore (cb) on subarus are 56.1 and Vw are 57.1 so you'd have to mill 1mm off the cb so they'll sit on the hub correctly.
(You could manage the 1mm with a file tbh)
Posted: Fri Apr 26, 2013 4:40 pm
by Match
C17LJR wrote:Subaru wheels will fit pcd wise as you say, they are 5x100. Although the centrebore (cb) on subarus are 56.1 and Vw are 57.1 so you'd have to mill 1mm off the cb so they'll sit on the hub correctly.
Ah I see. Where can I learn about other things like cb then as I'm clueless and I want to know what I'm buying haha
Posted: Fri Apr 26, 2013 6:19 pm
by vwpolo16v
Match wrote:Noob question I know but :roll:
Round ones :P
Posted: Fri Apr 26, 2013 9:15 pm
by Match
Round ones :P
Oh right thanks!
Posted: Fri Apr 26, 2013 9:46 pm
by Match
