UK-POLOS.NET - THE VW Polo Forum • Fittings for gas bonnet struts?
Posted: Fri Aug 02, 2013 7:51 pm
by Yeahhluke
There's a few gas bonnet struts on eBay and its a mod I really want to do, has anyone fitted them if so what fixings did you use? As the ones I've found doesn't say they come with any fixings? Any advice is much appreciated
Re: Re: Fittings for gas bonnet struts?
Posted: Fri Aug 02, 2013 8:51 pm
by andyc315
Yeahhluke wrote:There's a few gas bonnet struts on eBay and its a mod I really want to do, has anyone fitted them if so what fixings did you use? As the ones I've found doesn't say they come with any fixings? Any advice is much appreciated
You can buy the 9n bonnet lifter fixings from vw for around £10 a side.
Don't know if they will be any use for aftermarket ones though
Sent from my GT-I9100P using Tapatalk 2
Posted: Sat Aug 03, 2013 11:30 pm
by blazeguarder
I always thought that there was nowhere on the 9N3 bonnet to even mount any fixings for gas struts. Found a guide somewhere where the bloke had basically welded in a mounting point to fit the strut to...
Posted: Sun Aug 04, 2013 4:09 pm
by andyc315
blazeguarder wrote:I always thought that there was nowhere on the 9N3 bonnet to even mount any fixings for gas struts. Found a guide somewhere where the bloke had basically welded in a mounting point to fit the strut to...
you have to buy the plate the fixings mount onto, but the plate needs to be welded onto the inner wing
Posted: Mon Aug 05, 2013 8:56 am
by Yeahhluke
think im going to give it ago, cant be that hard to do as i know a welder and people have done it, and its not like the kits are expensive
