Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6561
Revision: 00043014 Serial number: CU501407085037
Coding: 0000020
Shop #: WSC 63002 002 1048576
VCID: 3A2E3B83D054E5DB5C7-806E
Posted: Sun Aug 22, 2021 8:37 pm
by iichel
That will be a RCY
Posted: Tue Aug 24, 2021 6:03 am
by ag69
Thanks iichel.
Is there anyway to find mapping or it is because of your sheer amount of work done on 6Rs
Posted: Tue Aug 24, 2021 7:24 am
by iichel
It should also be on the sticker in the boot with all equipment codes
Posted: Fri Aug 27, 2021 9:31 pm
by amer6R
Can someone confirm that polo 6r shares the same wishbone bushings as mk4 golf ?
Posted: Fri Aug 27, 2021 9:47 pm
by iichel
Yes same as MK1 Audi tt
Posted: Fri Aug 27, 2021 10:15 pm
by amer6R
Thank you
Posted: Fri Sep 17, 2021 1:32 pm
by amer6R
6Q0199851AP - Lemforder
The dimension are the large bush 80 mm, the smaller bush is 36 mm
the height( of 80 mm bushing) is 40 mm, the width of smaller bushing is 32 mm
the height of the smaller bushing is 50 mm
Bushing screw to screw is ~181-182 mm
Large bushing bolt opening is fi 11 mm
Will post the dimension of OEM doge bone mount. If you can source the large bushing that is 80x40 mm you can rebuild the doge bone mount or atleast the lemforder one.
Edit: I have just replaced mine OEM mount ( its also produced by Lemforder but it has Vw stamps )
- No engine diving under hard acceleration
- No jerking feeling that car is giving self throttle dow a hill or in stop go traffic.
Posted: Fri Sep 24, 2021 9:04 pm
by amer6R
Just want to add if someone ever needs.
GSP outer cv joint is great quality.
Disassembled mine today, tohough it was pita. It wasnt 0 play, felt like new. After one year. ( Note add extra 90g of grease into it)
And the price is 1/2 of SKF
Posted: Sat Sep 25, 2021 10:40 pm
by iichel
Anyone familair with part numbers for the brackets in yellow?
Posted: Sun Sep 26, 2021 9:57 pm
by amer6R
If i can remember correctly they can flip open, maybe the part number is hidden...
Try taking a pic of the part, and scan it with google lens maybe something comes back
Posted: Wed Oct 20, 2021 6:27 pm
by amer6R
If anyone needs, SNR is OEM bearing in polo 6R
Posted: Wed Oct 20, 2021 7:25 pm
by iichel
amer6R wrote: ↑Wed Oct 20, 2021 6:27 pm
