Page 29 of 30
Posted: Tue May 17, 2022 11:12 am
by iichel
yeah just get the BlueGT spoiler
Posted: Tue May 17, 2022 6:37 pm
by Noiseprojekt
iichel wrote: ↑Tue May 17, 2022 11:12 am
Wow, thanks!
I did not know that them existed!
Now i just got to find the part number
EDIT:
53 Left 6R6805945
54 Right 6R6805946
But i dont know if you'll need part 51, 6R6827989 "Bracket for spoiler" as well
- Skärmklipp.JPG (46.41 KiB) Viewed 20388 times
Posted: Sun Jul 03, 2022 10:52 am
by amer6R
Does anyone know what these clips are called?
The EGT wire clips into it on the turbo housing. It seems that KK3 dont fit on 1549vz
- IMG_20220703_114837.jpg (3.38 MiB) Viewed 19739 times
Posted: Mon Oct 03, 2022 12:19 pm
by amer6R
Can someone tell me what is the part number of terminal pins (male and female) for rear door connector ( 1K0 937 702 C) ?
Posted: Mon Oct 03, 2022 4:09 pm
by iichel
MCP 2.8 and MCP 1.5
Posted: Tue Oct 04, 2022 2:01 pm
by amer6R
Thank you!
Posted: Sat Feb 25, 2023 2:04 pm
by wolfie
In the past if I've wanted part number info I've used the parts catalogs on 7zap.com. They've generally been very good. However they appear to have updated the site and now it's a complete dogs dinner. Really struggling to use it now.
Where else can you gain access to VW part numbers??
Posted: Sat Feb 25, 2023 2:10 pm
by SRGTD
wolfie wrote: ↑Sat Feb 25, 2023 2:04 pm
Try this;
https://webautocats.com/en-gb/etka/volkswagen/
Posted: Sat Feb 25, 2023 2:16 pm
by wolfie
Cheers that was quick...
Thanks for the link.
Posted: Tue Mar 26, 2024 11:44 am
by Cruzor
1.Hi, does anybody know the part number for this beige trim piece? It’s also available in black which is what I’m looking for. I checked in ifinterface but it shows only the smaller fuse box door(you can see it’s a separate piece) in the diagram, so I’m asking here. Is this even removable?
Edit- 2. Also If someone can share the terminals and block part numbers needed for an 654 g85 steering sensor it’d be fantastic.
- C07447D9-7C6D-4969-A5D4-198A05A9CE93.jpeg (162 KiB) Viewed 1768 times
Posted: Tue Mar 26, 2024 2:24 pm
by iichel
the lower dash trim is not a separate part
G85 is connected to the T41 connector of the slip ring, those are all MQS
Posted: Tue Mar 26, 2024 3:58 pm
by Cruzor
Thank you for the help. Ahh that’s a bummer, I found a black glovebox for cheap and thought to make the whole dash black
Posted: Sun Apr 14, 2024 11:28 am
by Christian_13
Hello,
we have an 2012 Polo 6R 1.2TSI and want to change the Highline-Steering wheel to the genuine R-Line from the 6R
The basic one with no DSG-paddles or multifunction
I´m looking for the OEM-part.nr
I hope it is still available.
I only found the 6R0419091SBRU for the WRC
Posted: Mon Apr 29, 2024 2:20 pm
by limparka
Hello Guys!
I would like to change my front fog lights on my Polo 6R 2009. The right one is damaged so I thinking about to change all of them to a new one. Is the Polo 6R GTI Fog lights fits into the stock bumper? I know that the front bumpers are not the same, but maybe the lights have the same dimensions. The lights what I found are the next: 6R0941061F and 6R0941062F. I only have manual fog lights so I only need the light with only 1 bulb.
Thank you for your help.
Posted: Tue Apr 30, 2024 7:36 am
by CNK
limparka wrote: ↑Mon Apr 29, 2024 2:20 pm
Hello Guys!
No, will not fit, the shape is different (
Polo 6R - additional front lights)
Only fog lights for standard bumper of 6R are:
6R0941061C +
6R0941062C.
However, you may want to consider adding fog lights + DRLs (additional wiring harness will be required)
