Drivers Door and Boot not closing properly
Posted: Sun Nov 10, 2013 7:51 pm
by X_S60TTY
Hi Guys,
I bought my second Polo GTi but this one is a 9n3 instead of a 6r, I noticed that the drivers door does not close easily at all, I have tried loosening with a bit of the old WD40 but it didnt seem to do much so I wondered if anyone else has had a similar problem? Also I have a similar problem with the boot not shutting without having to slam it. Does anyone know of anything that I could check or that may help me? Cheers Scott
Re: Drivers Door and Boot not closing properly
Posted: Tue Nov 12, 2013 1:41 pm
by ieuan-j
I had the same problem with my drivers door, it just didn't seem to close as nicely as my passenger, so I sprayed the hinges /latch with white grease and it has loosened it up a bit, it still isn't quite as nice though.
Posted: Sun Nov 17, 2013 9:14 am
by GTi_Red
Check to see if the latch in the door and the catch on the b pillar line up together, the door may have dropped a bit causing the door to have to move up a bit when you close it
Posted: Mon Nov 18, 2013 7:52 am
by X_S60TTY
Cheers yeah Ill definitely have to try that, my mate has a R32 with a similar problem, Thanks for the suggestion
Posted: Tue Dec 17, 2013 12:32 pm
by GTi_Red
How did you get on with this?
Posted: Tue Dec 17, 2013 1:53 pm
by Tony Boi 92
GTi_Red wrote:How did you get on with this?
this
