Page 1 of 2
running at 70 degrees
Posted: Sun Jan 05, 2014 9:59 pm
by dantheram
I'm thinking the stat has gone or is it going to be the sensor?
any ideas?
P.S. VCDS shows no fault codes
Re: running at 70 degrees
Posted: Sun Jan 05, 2014 10:09 pm
by alexperkins
Are the rad pipes cool when running?
The temp sender may have gone as they can fail without any errors, though it's possibly the stat
Posted: Sun Jan 05, 2014 10:21 pm
by dantheram
i've replaced that sodding thing once! granted it was a few years back. i've not checked the pipes but i never get over 70 degrees.
Posted: Sun Jan 05, 2014 10:23 pm
by dantheram
do you know the part number mate? GSF sell me the wrong part 9 times out of 10
Posted: Sun Jan 05, 2014 10:24 pm
by alexperkins
Only use a genuine vw thermostat - the Gsf ones are absolute rubbish. I'll get a part number tomorrow.
Posted: Sun Jan 05, 2014 10:28 pm
by dantheram
alexperkins wrote:Only use a genuine vw thermostat - the Gsf ones are absolute rubbish. I'll get a part number tomorrow.
cheers mate, i'm after the sender first as it's cheaper. is it the green one with the horse shoe clip, that's on the right on the engine block?
Posted: Sun Jan 05, 2014 10:33 pm
by alexperkins
Correct. Again only use a genuine part. Copy parts are truly rubbish.
Posted: Mon Jan 06, 2014 9:03 am
by dantheram
Is there any way i can work out if it's the stat? i see you mention the rad pipes - if they're cool that would indicate the stat wouldnt it?
i'd sooner not be replacing things that are working ok.
P.S. Heater is blowing hot air
Posted: Mon Jan 06, 2014 5:21 pm
by dantheram
Checked the rad pipes - top is hotter than bottom after short drive, both are warm.
The car shows 90 degrees if left standing but as you drive the temp falls to 70. Looks nailed on stat to me
Posted: Mon Jan 06, 2014 7:10 pm
by alexperkins
That's the stat alright.
Posted: Wed Jan 08, 2014 10:38 pm
by dantheram
Alex, is it likely that the housing could be damaged? i keep reading about the little plastic bridge in the elbow of the housing being broken on other 6n's??
http://www.google.co.uk/url?sa=i&rct=j& ... 7046443059
Posted: Wed Jan 08, 2014 11:31 pm
by alexperkins
The 6n2 uses a cartridge style thermostat therefore the housing is very different. It's likely the stat has simply failed.
Posted: Thu Jan 09, 2014 10:54 am
by dantheram
ah i see, thanks for your help :D
Is this the correct stat?
http://www.mister-auto.co.uk/en/coolant ... 780G1.html
Posted: Thu Jan 09, 2014 11:13 am
by alexperkins
Correct - part number is 032121110C only £20+vat from VW to be fair - get one from your dealer. Genuine is always better
Posted: Thu Jan 09, 2014 9:16 pm
by dantheram
I've got the dealer one and some G13 for when I spill it all changing it haha
