Automatic headlight washers?
Wilxay
Post by Wilxay »
Has anyone with the headlight washers, happened to notice that sometimes they will wash themselves without driver input? My R Line has done it a couple of times now and im wondering if there is an intermittent fault?
Its worth pointing out that the wipers take a couple of strokes too, as if you have just pulled the windscreen washer, but not actually let any fluid come out of the jets. I hope you guys understand me.
Sent from my iPad using Your mum
ben4012
Re: Automatic headlight washers?
Post by ben4012 »
That's not right. They are supposed to work every xx times the screen washers are used bit with the screen washers.
And only when the headlights Are on
Wilxay
Post by Wilxay »
Yeah I know. It happened today.
I was driving along with headlights on (bi-xenon) when the wipers came on and did two sweeps with no washer fluid. Then I parked up at home and could see the suds splattered around the headlight.
Should I have it looked at under warranty? Or will I be wasting my time because they won't be able see what my problem is?
Sounds like the headlight washer pump may have a fault
Dealer should be able to diagnose it further
Wilxay
Post by Wilxay »
So I've got round to taking it the dealers about this issue because it happened again the other day. Will keep informed. That's if they actually find the problem. Trying to tell dealers about intermittent faults is horrible. It's like they don't even know anything about their own cars
Wilxay
Post by Wilxay »
So yeah no joy with this. As per usual with intermittent faults
